Working on a project to download a list of files from an FTP server and when running it dies right before downloading the last file.
#Log beginning of modification
#If the unmetered address list file size is larger than 0, begin
#Remove all previous entries
#Put the content of the txt file into the variable $content
#Get the total length of $content
:log info "Starting Hotspot Download"
:if ( [/file get [/file find name=file-list-hotspot.txt] size] > 0 ) do={
/tool fetch mode=ftp user=**USER** password="**PASSWORD**" address=update.**SERVER**.com src-path=~/filelist/hotspot.txt dst-path=file-list-hotspot.txt port=21
:local content [/file get [/file find name=file-list-hotspot.txt] contents] ;
:local contentLen [ :len $content ] ;
#Set lineEnd to 0
#Set line to null
#Set lastEnd to 0
:local lineEnd 0
:local line ""
:local lastEnd 0
#Beginning of do/while loop
#Set lineEnd to the first point in the line there's a newline char
#Set line to be whatever is between lastEnd and lineEnd
#Set lastEnd to be lineEnd + 1 (ready for new line)
:do {
:set lineEnd [:find $content "\n" $lastEnd ] ;
:set line [:pick $content $lastEnd $lineEnd] ;
:set lastEnd ( $lineEnd + 1 ) ;
#if the line is not empty (1st char is a newline) do the following
#if line is longer than 0 characters - fetch new file
#End if segment
#End do segment - while $lineEnd is smaller than the total length of the list
#End if segment
#Log completion
:if ( [:pick $line 0 1] != "\n" ) do={
:if ( [:len $line ] != 0 ) do={ /tool fetch mode=ftp user=**USER** password="**PASSWORD**" address=update.**SERVER**.com src-path=[:put ("~/hotspot/". $line)] dst-path=[:put ("hotspot/". $line)] }
} while ($lineEnd < $contentLen)
:log info "Hotspot Download Complete"
The list:
favicon.ico
manifest.json
json/status.html
redirect.html
alogin.html
admin/login.html
status.html
errors.txt
logout.html
browserconfig.xml
error.html
login.html
Can someone take a look at the if/do/while and see what I’m missing?
