Hi all,
I have a firewall rule:
“chain=forward src-address=!10.x.x.x dst-address=x.x.x.0/25
protocol=icmp action=drop”
I want to add a script to enable this law at 7PM and disable it at 7am, can someone tell how to do this please.
Hi all,
You do not need any script to accomplish it, use the latest RotuerOS version and matcher=time, to enable/disable firewall rule per time.
Thank you sergejs, but I seem to have a problem. Where do I see the matcher?
Hello sergejs,
I have seen the time setup on firewall filter forward, but for some reason, it doesnt work in 2.9.34 according to the time I set. Do I need to do anything in firewall Mangle?
hello sergejs,
I have tried but cant seem to figure out how to do this. Following what Im trying to block and how can you please assist me in giving me a guideline on what to do.
All efforts are highly appreciated.
Thanks again.
Make sure that ‘system clock’ time-zone is equal to +00:00, then time should work correctly for the queues (2.9 release).
RouterOS3 beta release works correctly with any time-zone settings.
