Help with setting up WireGuard on single port
Hi. I’m trying to set up hAP router so ether2-4 ports and all wifi networks works as usual, but ether5 should route traffic via WireGuard (to connect device, not capable of using VPN by itself). I thought about something like this
  1. Creating separate bridge (I named it bridge-wg);
  2. Connect ether5 port to this pridge;
  3. Route traffic from this bridge to WireGuard connection.
So basically something like ether5 → bridge-wg → wireguard-connection → WAN. I also connected to ISP via WiFi (so wlan1 is set to station mode, but that is probably irrelevant).
After reading multiple articles and forum threads I was able to set it up, so simple request to service which return IP address give me this
My configuration:
$ curl --interface enp87s0u1 2ip.ru
65.109.XXX.YYY   # IP address of my WireGuard server in Hetzner
$ curl --interface wlp0s20f3 2ip.ru
78.109.72.75     # Same as connected directly to ISP router
But beside that most of the requests fails with timeout (both via curl and browser). After a long time some of them loads, but mostly not. If I disable routing table, created to force traffic into WireGuard connection (so it become ether5 → bridge-wg → WAN), everything works fine.
VPN server itself works fine, I use it with multiple devices and no problem.
Another interesting thing - if I additionally enable same WireGuard connection on my laptop (on top of everything above), everything works perfectly.
Unfortunately I was not able to understand what could be wrong and how to debug this.
# jul/02/2023 19:06:04 by RouterOS 7.1.1
# software id = BVAZ-T5VF
# model = RBD52G-5HacD2HnD
# serial number = D7160C140BE1
add admin-mac=48:8F:5A:80:1E:16 auto-mac=no comment=defconf name=bridge
add comment="Internet through remote WireGuard server" name=bridge-wg
/interface wireguard
add comment="Internet through remote WireGuard server" listen-port=13231 mtu=\
    1420 name=flowneee-wg
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk comment="Internet through WiFi" mode=\
    dynamic-keys name=wifi_in supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=internal \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n comment=\
    "Internet through WiFi (set as station, WiFi client)" country=armenia \
    disabled=no distance=indoors installation=indoor security-profile=\
    wifi_in ssid=<ISP_wifi_name> wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=armenia disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge security-profile=internal ssid=\
    mtk-5 wireless-protocol=802.11
add disabled=no mac-address=4A:8F:5A:80:1E:1A master-interface=wlan1 name=\
    wlan3 security-profile=internal ssid=mtk-2.4 wds-default-bridge=bridge \
    wps-mode=disabled
/interface wireless nstreme
set wlan1 comment="Internet through WiFi (set as station, WiFi client)"
/interface wireless manual-tx-power-table
add comment="Internet through remote WireGuard server" name=dhcp-wg-pool \
    ranges=192.168.90.10-192.168.90.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp-wg-pool comment=\
    "Internet through remote WireGuard server" interface=bridge-wg name=\
    dhcp-wg
/routing table
add comment="Internet through remote WireGuard server" disabled=yes fib name=\
    wg
add bridge=bridge-wg comment="Internet through remote WireGuard server" \
    interface=ether5
add bridge=bridge comment=\
    "Internet through WiFi (disable due to used as WiFi client)" disabled=yes \
    interface=wlan1
add bridge=bridge comment=defconf interface=wlan2
add comment="Internet through remote WireGuard server" interface=bridge-wg \
    list=LAN
add comment="Internet throught WiFi" interface=wlan1 list=WAN
add comment="Internet through remote WireGuard server" interface=flowneee-wg \
    list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0,::/0 endpoint-address=65.109.XXX.YYY \
    endpoint-port=1750 interface=flowneee-wg persistent-keepalive=40s \
    public-key="<public-key>"
    192.168.88.0
add address=192.168.90.1/24 interface=bridge-wg network=192.168.90.0
add address=10.200.200.8 comment="Internet through remote WireGuard server" \
    interface=flowneee-wg network=10.200.200.0
add comment="Internet through WiFi" interface=wlan1
    192.168.88.1
add address=192.168.90.0/24 dns-server=192.168.90.1 gateway=192.168.90.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    "Internet through remote WireGuard server" in-interface=bridge-wg \
    out-interface=flowneee-wg
    connection-state=invalid
add comment="Internet through remote WireGuard server" dst-address=0.0.0.0/0 \
    gateway=flowneee-wg routing-table=wg
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup comment="Internet throught remote WireGuard server" \
    disabled=no dst-address=0.0.0.0/0 src-address=192.168.90.0/24 table=wg
/system clock
set time-zone-name=Asia/Yerevan
/system routerboard settings
set cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
(1) No need for a separate bridge. Get rid of it and the bridge entry for ether5 in /interface bridge ports and interface member…
(2) You already have created a separate subnet for these users and thus simply assign it to interface ether5.
add address=192.168.90.1/24 interface=ether5 network=192.168.90.0
“Internet through remote WireGuard server” interface=ether5 name=
dhcp-wg
(3) {you already have a table - ensure you ENABLE IT! }
add fib name=WG
(4) {you already have the routing rule BUT ITS WRONG USE THIS !!
add src-address=192.168.90.0/24 subnet action=lookup table=WG
(5) You already have the additional route required.
add dst-address=0.0.0.0/0 gwy=flowneee-wg table=WG
(6) FIX THE IP ADDRESS For WIREGUARD should be:
add address=10.200.200.8**/24** comment=“Internet through remote WireGuard server”
(7) Forward chain firewall rules: Okay this rule should go after the default rule of invalid traffic not before it.
However I have a question WHY is this rule here??
“Internet through remote WireGuard server” in-interface=bridge-wg
The traffic should already be permitted as you have nothing blocking such traffic in the ruleset.
The only thing you block in the forward chain is WAN to LAN traffic that is not port forwarding??
Recommended: For better granular control and to only allow needed traffic much better to use this setup.
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=forward comment=“allow internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“WG traffic” in-interface=ether5 out-interface=flowneee-wg
add action=accept chain=forward comment=“allow port forwarding” connection-nat-state=dstnat { disable or remove if not required }
add action=drop chain=forward comment=“drop all else”
Cannot comment on some parts as its not clear if the WG is going to a third party provider or what ???
