In my homelab, I have a single WAN gateway (Ether1) with two working public IPs on it, the second public IP is reserved for a webserver. SSTP VPN Server is also setup and listening on port 443. I also have the webserver using HTTPS. Now I have two conflicting services using the same port.
It seems that the SSTP VPN Server is listening to all IP addresses on the WAN Gateway for port 443 - is there a way to restrict the SSTP VPN Server on the Mikrotik to only listen to one of the two public IP’s assigned to the WAN gateway and not listen to the second public IP that is dstnat’ed to the Webserver? I don’t want to change the SSTP VPN Server’s listening port.
