Help with subnet for wifi 2.4GHz
Hi people! How are you?
After research and hours of testing I can’t make it works… Unfortunately…
I need to set a subnet exclusive to the wifi 2.4GHz interface with access to Internet, local DNS server and local NTP server.
Do not want to use VLANs and do not need mesh (for the 2.4GHz WiFi).
Can you help me, please? :frowning:
The network diagram is:
The main router (gateway) configuration export:
# sep/08/2022 23:07:22 by RouterOS 7.5
# software id = FZPI-1FMU
# model = RB760iGS
add admin-mac=74:4D:28:AD:73:42 auto-mac=no comment=defconf name=bridge
add admin-mac=3E:C6:77:F7:7D:13 auto-mac=no name=bridge-iot
set [ find default-name=ether1 ] name=ether1-lan
set [ find default-name=ether2 ] name=ether2-wan
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes poe-out=off
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes allow=pap,chap disabled=no interface=ether2-wan \
    keepalive-timeout=30 name=pppoe user=cliente@cliente
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=no use-network-apn=no \
    use-peer-dns=no
add name=dhcp-pool1 ranges=192.168.1.101-192.168.1.254
add name=dhcp-iot ranges=192.168.2.11-192.168.2.100
add address-pool=dhcp-pool1 allow-dual-stack-queue=no interface=bridge name=\
    dhcp-srv1
add address-pool=dhcp-iot allow-dual-stack-queue=no interface=bridge-iot \
    name=dhcp-iot
/port
set 0 name=serial0
/caps-man aaa
set called-format=mac mac-format=""
add bridge=bridge ingress-filtering=no interface=ether1-lan
/ip settings
set rp-filter=loose
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
    forward=no max-neighbor-entries=8192
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=ether2-wan list=WAN
add interface=pppoe list=WAN
add interface=bridge-iot list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
add address=192.168.15.2/24 comment="Enable to acess ISP Bridged Modem" \
    interface=ether2-wan network=192.168.15.0
add address=192.168.2.1/24 interface=bridge-iot network=192.168.2.0
/ip cloud
set update-time=no
/ip dhcp-server alert
add disabled=no interface=ether1-lan valid-server=3E:C6:77:F7:7D:13
/ip dhcp-server lease
add address=192.168.1.10 client-id=1:4c:5e:c:d5:3b:49 mac-address=\
    4C:5E:0C:D5:3B:49 server=dhcp-srv1
add address=192.168.1.4 client-id=1:e4:8d:8c:9f:8c:23 mac-address=\
    E4:8D:8C:9F:8C:23 server=dhcp-srv1
add address=192.168.1.2 client-id=1:64:d1:54:c6:8d:2e mac-address=\
    64:D1:54:C6:8D:2E server=dhcp-srv1
add address=192.168.1.8 mac-address=04:18:D6:06:7F:E3 server=dhcp-srv1
add address=192.168.1.32 comment="Pi-Hole DNS" mac-address=B8:27:EB:61:D9:8E \
    server=dhcp-srv1 use-src-mac=yes
add address=192.168.1.31 comment="NTP Server" mac-address=D8:B0:4C:F0:00:55 \
add address=192.168.1.3 mac-address=CC:2D:E0:E1:23:42 server=dhcp-srv1
add address=192.168.1.0/24 comment="DHCP Server Subnet 1" dns-server=\
    192.168.1.32 gateway=192.168.1.1 netmask=24 ntp-server=192.168.1.31
add address=192.168.2.0/24 comment="DHCP Server Subnet 2" dns-server=\
    192.168.1.32 gateway=192.168.2.1 netmask=24 ntp-server=192.168.1.31
set servers=192.168.1.32
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add address=192.168.1.32 name=pi.hole
/ip firewall address-list
add address=0.0.0.0/8 comment="defconf: RFC6890" list=no_forward_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=no_forward_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=no_forward_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=no_forward_ipv4
add address=127.0.0.0/8 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.0.0/24 comment="defconf: RFC6890" list=bad_ipv4
add address=192.0.2.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=198.51.100.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=203.0.113.0/24 comment="defconf: RFC6890 documentation" list=\
    bad_ipv4
add address=240.0.0.0/4 comment="defconf: RFC6890 reserved" list=bad_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=10.0.0.0/8 comment="defconf: RFC6890" list=not_global_ipv4
add address=100.64.0.0/10 comment="defconf: RFC6890" list=not_global_ipv4
add address=169.254.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=172.16.0.0/12 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.0.0.0/29 comment="defconf: RFC6890" list=not_global_ipv4
add address=192.168.0.0/16 comment="defconf: RFC6890" list=not_global_ipv4
add address=198.18.0.0/15 comment="defconf: RFC6890 benchmark" list=\
    not_global_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=not_global_ipv4
add address=224.0.0.0/4 comment="defconf: multicast" list=bad_src_ipv4
add address=255.255.255.255 comment="defconf: RFC6890" list=bad_src_ipv4
add address=0.0.0.0/8 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=224.0.0.0/4 comment="defconf: RFC6890" list=bad_dst_ipv4
add address=192.168.1.0/24 list=LAN-Subnets
add address=192.168.2.0/24 list=LAN-Subnets
add action=accept chain=input comment="defconf: accept ICMP after RAW" \
    protocol=icmp
    established,related,untracked
add action=drop chain=input comment="defconf: drop all coming from WAN" \
    in-interface=pppoe log-prefix=DROP-FROM-WAN
    "defconf: accept all that matches IPSec policy" disabled=yes \
    ipsec-policy=in,ipsec
    connection-state=invalid
add action=drop chain=forward comment="defconf: drop NTP out" \
    connection-state="" dst-port=123 log=yes log-prefix=NTP-OUT: \
    out-interface-list=!LAN protocol=udp
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=pppoe
add action=drop chain=forward comment="defconf: drop bad forward IPs" \
    src-address-list=no_forward_ipv4
    dst-address-list=no_forward_ipv4
/ip firewall mangle
add action=mark-packet chain=prerouting in-interface=ether2-wan \
    layer7-protocol=*1 log=yes log-prefix=BLCK-EXE-DWNLD new-packet-mark=\
    EXE-pckt passthrough=no
add action=accept chain=srcnat comment=\
    ipsec-policy=out,ipsec
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
    out-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" log-prefix=\
    MASQ
add action=dst-nat chain=dstnat connection-type="" dst-limit=\
    1,5,dst-address/1m40s dst-port=53 log-prefix="[RED]DNS-OUT[UDP]" \
    protocol=udp src-address=!192.168.1.32 to-addresses=192.168.1.32 \
    to-ports=53
add action=dst-nat chain=dstnat dst-port=53 log-prefix="[RED]DNS-OUT[TCP]" \
    protocol=tcp src-address=!192.168.1.32 to-addresses=192.168.1.32 \
    to-ports=53
add action=dst-nat chain=dstnat dst-port=123 in-interface-list=LAN \
    log-prefix="[RED]NTP-OUT[UDP]" protocol=udp to-addresses=192.168.1.31 \
    to-ports=123
add action=dst-nat chain=dstnat dst-port=123 log-prefix="[RED]NTP-OUT[TCP]" \
    protocol=tcp to-addresses=192.168.1.31 to-ports=123
/ip firewall raw
add action=accept chain=prerouting comment=\
    "defconf: enable for transparent firewall" disabled=yes
add action=accept chain=prerouting comment="defconf: accept DHCP discover" \
    dst-address=255.255.255.255 dst-port=67 in-interface-list=LAN log=yes \
    log-prefix=DHCP-DISCOVER protocol=udp src-address=0.0.0.0 src-port=68
add action=drop chain=prerouting comment="defconf: drop bogon IP's" \
    src-address-list=bad_ipv4
add action=drop chain=prerouting comment=\
    "defconf: drop bogon IP's (Disrupt CAPsMAN!)" dst-address-list=bad_ipv4 \
    log-prefix=DROP-BOGON
    src-address-list=bad_src_ipv4
    dst-address-list=bad_dst_ipv4 log-prefix=DROP-BOGON-IP4:
    "defconf: accept ISP bridge from WAN" in-interface=pppoe log-prefix=\
    ACC-NOT-GLOBAL: protocol=tcp src-address=192.168.15.1 src-port=80
add action=drop chain=prerouting comment="defconf: drop non global from WAN" \
    in-interface=pppoe log-prefix=DROP-NOT-GLOBAL: src-address-list=\
    not_global_ipv4
    "defconf: drop forward to local lan from WAN" dst-address=192.168.1.0/24 \
    in-interface=pppoe
    "defconf: drop local if not from default IP range" in-interface-list=LAN \
    src-address-list=!LAN-Subnets
    src-address=!192.168.1.0/24
add action=drop chain=prerouting comment="defconf: drop bad UDP" port=0 \
    protocol=udp
add action=jump chain=prerouting comment="defconf: jump to ICMP chain" \
    jump-target=icmp4 protocol=icmp
add action=jump chain=prerouting comment="defconf: jump to TCP chain" \
    jump-target=bad_tcp protocol=tcp
    "defconf: accept everything else from LAN" in-interface-list=LAN \
    log-prefix=ACCEPT-RAW-LAN
    "defconf: accept everything else from WAN" in-interface=pppoe log-prefix=\
    ACCEPT-RAW-WAN
add action=drop chain=prerouting comment="defconf: drop the rest"
add action=drop chain=bad_tcp comment="defconf: TCP flag filter" disabled=yes \
    protocol=tcp tcp-flags=!fin,!syn,!rst,!ack
add action=drop chain=bad_tcp comment=defconf disabled=yes protocol=tcp \
    tcp-flags=fin,syn
    tcp-flags=fin,rst
    tcp-flags=fin,!ack
    tcp-flags=fin,urg
    tcp-flags=syn,rst
    tcp-flags=rst,urg
add action=drop chain=bad_tcp comment="defconf: TCP port 0 drop" disabled=yes \
    port=0 protocol=tcp
add action=accept chain=icmp4 comment="defconf: echo reply" disabled=yes \
    icmp-options=0:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: net unreachable" disabled=yes \
    icmp-options=3:0 protocol=icmp
add action=accept chain=icmp4 comment="defconf: host unreachable" disabled=\
    yes icmp-options=3:1 protocol=icmp
add action=accept chain=icmp4 comment="defconf: protocol unreachable" \
    disabled=yes icmp-options=3:2 protocol=icmp
add action=accept chain=icmp4 comment="defconf: port unreachable" disabled=\
    yes icmp-options=3:3 protocol=icmp
add action=accept chain=icmp4 comment="defconf: fragmentation needed" \
    disabled=yes icmp-options=3:4 protocol=icmp
add action=accept chain=icmp4 comment="defconf: echo" disabled=yes \
    icmp-options=8:0 limit=5,10:packet protocol=icmp
add action=accept chain=icmp4 comment="defconf: time exceeded " disabled=yes \
    icmp-options=11:0-255 protocol=icmp
add action=drop chain=icmp4 comment="defconf: drop other icmp" disabled=yes \
    protocol=icmp
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl disabled=yes
/ip traffic-flow
set enabled=yes interfaces=pppoe
/ipv6 firewall address-list
add address=fe80::/10 comment="defconf: RFC6890 Linked-Scoped Unicast" list=\
    no_forward_ipv6
add address=ff00::/8 comment="defconf: multicast" list=no_forward_ipv6
add address=2001::/23 comment="defconf: RFC6890" list=bad_ipv6
add address=100::/64 comment="defconf: RFC6890 Discard-only" list=\
    not_global_ipv6
add address=2001::/32 comment="defconf: RFC6890 TEREDO" list=not_global_ipv6
add address=2001:2::/48 comment="defconf: RFC6890 Benchmark" list=\
    not_global_ipv6
add address=fc00::/7 comment="defconf: RFC6890 Unique-Local" list=\
    not_global_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_dst_ipv6
add address=::/128 comment="defconf: unspecified" list=bad_src_ipv6
add address=ff00::/8 comment="defconf: multicast" list=bad_src_ipv6
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 firewall raw
add action=accept chain=prerouting comment="defconf: RFC4291, section 2.7.1" \
    dst-address=ff02::1:ff00:0/104 icmp-options=135 protocol=icmpv6 \
    src-address=::/128
    src-address-list=bad_ipv6
    dst-address-list=bad_ipv6
    "defconf: drop packets with bad SRC ipv6" src-address-list=bad_src_ipv6
    "defconf: drop packets with bad dst ipv6" dst-address-list=bad_dst_ipv6
    in-interface-list=WAN src-address-list=not_global_ipv6
add action=jump chain=prerouting comment="defconf: jump to ICMPv6 chain" \
    jump-target=icmp6 protocol=icmpv6
    "defconf: accept local multicast scope" dst-address=ff02::/16
    "defconf: drop other multicast destinations" dst-address=ff00::/8
    "defconf: accept everything else from WAN" in-interface-list=WAN
add action=accept chain=icmp6 comment=\
    "defconf: rfc4890 drop ll if hop-limit!=255" dst-address=fe80::/10 \
    hop-limit=not-equal:255 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: dst unreachable" \
    icmp-options=1:0-255 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: packet too big" icmp-options=\
    2:0-255 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: limit exceeded" icmp-options=\
    3:0-1 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: bad header" icmp-options=\
    4:0-2 protocol=icmpv6
    "defconf: Mobile home agent address discovery" icmp-options=144:0-255 \
    protocol=icmpv6
    "defconf: Mobile home agent address discovery" icmp-options=145:0-255 \
    protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: Mobile prefix solic" \
    icmp-options=146:0-255 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: Mobile prefix advert" \
    icmp-options=147:0-255 protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: echo request limit 5,10" \
    icmp-options=128:0-255 limit=5,10:packet protocol=icmpv6
add action=accept chain=icmp6 comment="defconf: echo reply limit 5,10" \
    icmp-options=129:0-255 limit=5,10:packet protocol=icmpv6
    "defconf: rfc4890 router solic limit 5,10 only LAN" hop-limit=equal:255 \
    icmp-options=133:0-255 in-interface-list=LAN limit=5,10:packet protocol=\
    icmpv6
    "defconf: rfc4890 router advert limit 5,10 only LAN" hop-limit=equal:255 \
    icmp-options=134:0-255 in-interface-list=LAN limit=5,10:packet protocol=\
    icmpv6
    "defconf: rfc4890 neighbor solic limit 5,10 only LAN" hop-limit=equal:255 \
    icmp-options=135:0-255 in-interface-list=LAN limit=5,10:packet protocol=\
    icmpv6
    "defconf: rfc4890 neighbor advert limit 5,10 only LAN" hop-limit=\
    equal:255 icmp-options=136:0-255 in-interface-list=LAN limit=5,10:packet \
    protocol=icmpv6
    "defconf: rfc4890 inverse ND solic limit 5,10 only LAN" hop-limit=\
    equal:255 icmp-options=141:0-255 in-interface-list=LAN limit=5,10:packet \
    protocol=icmpv6
    "defconf: rfc4890 inverse ND advert limit 5,10 only LAN" hop-limit=\
    equal:255 icmp-options=142:0-255 in-interface-list=LAN limit=5,10:packet \
    protocol=icmpv6
add action=drop chain=icmp6 comment="defconf: drop other icmp" protocol=\
    icmpv6
/system clock
set time-zone-name=America/Sao_Paulo
/system identity
set name=RTR-GATEWAY
/system logging
add disabled=yes prefix=NTP-LOGs topics=ntp
add disabled=yes topics=dns
add disabled=yes topics=pppoe
add topics=dhcp,debug
add disabled=yes prefix=CAPS topics=caps,debug
add disabled=yes prefix=WIFI topics=wireless,debug
add disabled=yes prefix=RAW topics=raw,info
/system ntp client
set enabled=yes
/system ntp client servers
/system routerboard settings
set auto-upgrade=yes
/system watchdog
set ping-timeout=2m watch-address=1.1.1.1
/tool bandwidth-server
set enabled=no
/tool graphing
set store-every=hour
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
And… The RBcAPGi-5acD2nD config export is:
# sep/21/2022 01:02:14 by RouterOS 7.5
# software id = ER1U-M8FA
# model = RBcAPGi-5acD2nD
add admin-mac=74:4D:XX:XX:XX:XX auto-mac=no name=bridge
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac country=brazil disabled=no \
frequency-mode=superchannel installation=indoor mode=ap-bridge ssid=HomeWiFi \
wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add name=LAN
add name=WAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=iot-wlan-pwd supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=etsi disabled=no \
frequency=2447 mode=ap-bridge security-profile=iot-wlan-pwd ssid=iotwifi \
/system ntp key
add key-id=1
add bridge=bridge interface=wlan2
add bridge=bridge interface=wlan1
/ip settings
set rp-filter=loose
set detect-interface-list=LAN
add interface=bridge list=LAN
add address=192.168.1.7/24 interface=bridge network=192.168.1.0
set servers=192.168.1.22
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main suppress-hw-offload=no
/ip service
/system clock
/system identity
set name=XPTO
/system logging
add disabled=yes topics=wireless,debug
add disabled=yes topics=interface,debug
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
add address=192.168.1.20 auth-key=1
/tool mac-server
Why don’t you want to use VLAN?
What does mesh have to do with this?
:Your request is illogical.
You want the router to provide DHCP to a bunch of different LANs but somehow push this over a managed switch.
When you want to open your mind to logical processes that work, I can be of assistance otherwise moving on.
VLAN, then? Right? Let’s go!
Can you help, please?
Your assistance is really appreciated!
1 - assign vlans for EVERY SUBNET
2 - make it clear which is your management subnet
a. where all smart devices will have their IP on, (typically set manually on both the smart device and the mT dhcp leases for that vlan).
b. where admin will normally access the router for config purposes, could be a normal trusted lan for example.
c. create an interface list item for MANAGE and assign the trusted vlan to this interface list as a member
d. ensure neighbours discovery and mac winbox setting use this interface list (MANAGE)
3. assign interface of each vlan upon creation to the single bridge.
4. each vlan gets 4 items, ip address, ip pool, dhcp server and dhcp server network
5. Create /interface bridge ports
6. Create /interface bridge vlans to match
7. Adjust firewall rules to ensure needed traffic is allowed.
8. Make Changes to LAN Interface List ( remove bridge and add all vlans typically)
9 . Enable vlan filtering on the bridge itself.
10. view /export to see if any errors crop up…
Help for firewall rules.
https://forum.mikrotik.com/viewtopic.php?t=180838
Suggest the easiest thing to do when configuring a bridge is to use one port on the router to do the configuration and to keep in your back pocket to access the router in an emerg where router bridge hickups…
https://forum.mikrotik.com/viewtopic.php?t=181718
Guidance on vlans using this method…
Hi!
Sorry for the late response… I was dealing with some personal questions…
I’m having a little trouble understanding some things… so I humbly ask for comprension and patience from the colleagues of the forum…
Here is the print of neighbors connected to my gateway (192.168.1.1):
#  INTERFACE   ADDRESS4      BOARD                VERSION
0  ether1-lan
   bridge
1  ether1-lan  192.168.1.2   CRS326-24G-2S+       7.5 (stable) Aug/30/2022 09:25:53
   bridge
2  ether1-lan  192.168.1.3   RB962UiGS-5HacT2HnT  7.5 (stable) Aug/30/2022 09:25:53
   bridge
3  ether1-lan  192.168.1.4   RB951G-2HnD          7.5 (stable) Aug/30/2022 09:25:53
   bridge
4  ether1-lan  192.168.1.5   RB960PGS             7.5 (stable) Aug/30/2022 09:25:53
   bridge
5  ether1-lan  192.168.1.6   RB962UiGS-5HacT2HnT  7.5 (stable) Aug/30/2022 09:25:53
   bridge
6  ether1-lan  192.168.1.7   RBcAPGi-5acD2nD      7.5 (stable) Aug/30/2022 09:25:53
   bridge
7  ether1-lan  192.168.1.9   RB260GSP             1.17
   bridge
8  ether1-lan  192.168.1.10  RB951G-2HnD          7.5 (stable) Aug/30/2022 09:25:53
   bridge
9  ether1-lan  192.168.1.11  RBcAPGi-5acD2nD      7.5 (stable) Aug/30/2022 09:25:53
   bridge
Below is the print of neighbors connected to my “main” switch (192.168.1.2) CRS326-24G-2S+ (Running RouterOS):
 0  ether2     192.168.1.4    RB951G-2HnD          7.5 (stable) Aug/30/2022 09:25:53
    bridge
 1  ether4     192.168.1.6    RB962UiGS-5HacT2HnT  7.5 (stable) Aug/30/2022 09:25:53
    bridge
 2  ether6
    bridge
 3  ether6     192.168.1.1    RB760iGS             7.5 (stable) Aug/30/2022 09:25:53
    bridge
 4  ether6     192.168.1.7    RBcAPGi-5acD2nD      7.5 (stable) Aug/30/2022 09:25:53
    bridge
 5  ether6     192.168.1.9    RB260GSP             1.17
    bridge
 6  ether6     192.168.1.10   RB951G-2HnD          7.5 (stable) Aug/30/2022 09:25:53
    bridge
 7  ether6     192.168.1.11   RBcAPGi-5acD2nD      7.5 (stable) Aug/30/2022 09:25:53
    bridge
 8  ether8     192.168.1.3    RB962UiGS-5HacT2HnT  7.5 (stable) Aug/30/2022 09:25:53
    bridge
 9  ether8     192.168.1.5    RB960PGS             7.5 (stable) Aug/30/2022 09:25:53
    bridge
10  ether8     192.168.1.121
    bridge
Just for clarifying a little bit the scenario: The CRS326-24G-2S+ isn’t direct connected to the gateway (due to physical impossibilities to route UTP cables). There is a RBcAPGi-5acD2nD (192.168.1.7) making the “interconnection” between the gateway and the switch.
Well… Now my questions:
  1. How should I configure the trunk on the switch?
  2. What trunk setup I will need to do on RBcAPGi (that makes the physical “connection” between the gateway and switch)?
  3. Is there any way to test a VLAN setup between two connected mikrotik devices without disrupting the LAN? How?
Thank you!!!
I would set up a capsman.
Then all the wlan interfaces would be collected on one device. Combine them in a bridge, configure all network settings and routing.
Capsman will build all the necessary connections on its own
I am not a fan of capsman as it adds a layer of complexity to the equation but for this many APs it may make sense.
My experience setting up a device for wifi ( AP/Switch ) is very good, and it can be done in minutes without capsman and I prefer that method.
Simple clean.
If you go the capsman route, be prepared to lose any remaining hair you have LOL.
Can you confirm that the ONLY ROUTER in the mix (or MT device acting as a router) is the 760 and the rest of the MT devices are acting as AP/switches or switches??
Can you confirm throughout this entire network you are only using two subnets, one for LAN traffic all users, and one for iot devices ??
Hi @Ca6ko! How are you?
I think CAPsMAN could be an alternative… Thank you!
Hi, @anav! Are you good?
In reality all MT devices are using only one subnet. (By the way: I’ve just replaced the configuration of the RBcAPGi-5acD2nD with the correct (“cleaned”) one at my main post.)
The devices with WiFi interface(s) are configured essentially with a bridge grouping all interfaces together, one IP address assigned to the bridge and that basic routing table…
I can post the config of any other MT device. Just let me know…
A segmented guest 5GHz WiFi network would be nice but not essential.
In another hand the mesh for the 5GHz WiFi is essential (I’ve already made the mesh config once but, with the upgrade to RouterOS v7 and segmentation in mind, I’ve cleaned every device).
Once again…
Thank you very much!
