Help with this configuration with multiple VLAN/NAT
Hello.
I have to ask if it possibile to realize this configuration.
I have a 951-2n with 6.14
I would like to achieve this:
RB addresses:
VLAN6: 100.64.8.104/24
VLAN100: 192.168.0.240/24
LAN: 192.168.0.254/24
the VLAN6 is the “wan” part
the VLAN100 is just a passthrough vlan (bridge mode)
The LAN is the LAN of the customer, and his external network is the VLAN6
eth1: VLAN 100 and 6 tagged.
eth2: LAN
eth3: LAN
eth4: LAN
eth5: VLAN100 untagged
wlan0: bridged to LAN (wpa2-aes key)
wlan1 (virtual AP): VLAN100 untagged (wi-fi with no security)
so:
the ETH1 ends in a HP1700-8 switch that can accept both VLAN 6 and 100
The VLAN100 is a vlan where my public hot-spot network is placed, with a central hot-spot and central dhcp.
The LAN part is 192.168.0.254/24, with DHCP service on it (lan part)
The VLAN6 100.64.6.104/24 is the WAN address (remote gw is 100.64.6.254/24)
How can I configure the vlan part of the network?
thank you
Hi Elia,
if you are referring to the Routerboard :
If i’m correct you should be doing something like this (don’t shoot me of i’m partially wrong, i’m doing this without a routerboard on my desk :slight_smile: )
create VLAN 6, bind it to ETH1 and give it the correct IP
then Create VLAN100 and bind it to ETH1 , then create a new bridge and bridge this VLAN to eth5.. AND give that the correct IP.
Let us know how you are proceeding!
Menno
Hello.
I would like to have eth1 as a trunk port, and the RB should answer on eth1 (via VLAN6 at 100.64.6.104/24).
Also incoming from eth1 should pass VLAN100 and a wifi shoot to VLAN100 untagged via wlan interface (virtual ap)
Hi Elia,
ok, so you should bridge it with the VirtualAP interface as well.
Not having that much experience with that, so someone correct me if i’m wrong?
