Help with this configuration
Hello, i have this scenario one Routerboard 333 with 3 R52h with 3 sector panel array, one sector for each card, my question is, could i have the same ssid for each card, and the channel selection? the configuration will be ap-bridge i would like to have mac address access control besides wep.
thanks for the help.
infinet -
You can use the same SSID if you want.
You cannot use the same channel on all three - there would be too much interference between the cards - they would interfere with each other - especially if one is listening and another in TX’ing.
MAC ‘athentication’ is under the Wireless / Access tab in Winbox…
