I am trying to setup the following:
3 networks:
10.160.250.0/24 - Public Network
10.160.251.0/24 - Private Network
10.160.252.0/24 - Front Network
I have everything setup and it is all working except I am not getting internet access on any of the networks!
eth1: Comcast switch/modem its ip is 10.1.10.1
eth2: Public Network
eth3: Private Network
eth4: Front network
Here is my config file:
apr/22/2015 17:51:56 by RouterOS 6.28
software id = 8XY6-SF8M
add name=dhcp_pool1 ranges=10.160.250.100-10.160.250.254
add name=dhcp_pool2 ranges=10.160.251.100-10.160.251.254
add address-pool=dhcp_pool1 disabled=no interface=ether2 lease-time=3d name=
Public-Network
add address-pool=dhcp_pool2 disabled=no interface=ether3 lease-time=3d name=
Private-Network
/port
set 0 name=serial0
add address=10.160.250.0/24 interface=ether2 network=10.160.250.0
add address=10.160.251.0/24 interface=ether3 network=10.160.251.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=ether1
add address=10.160.250.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.160.250.1
add address=10.160.251.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.160.251.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=ether1 src-address=
10.160.250.0/24
10.160.151.0/24
add distance=1 gateway=10.1.10.1
/romon port
add disabled=no
/system clock
set time-zone-name=America/Detroit
Thanks for the help!
Note: I have not yet added the 3rd network (front network) thats why its not in the config.
evince
April 23, 2015, 7:29pm
3
Can you post the configuration of your firewall rules please?
I’m assuming that this is an artifact of your IP address sanitization - but your configuration shows the interface IPs as 10.160.25x.0/24 – that’s the network prefix and is an invalid IP address. Perhaps you’re really configured with 10.160.25x.1/24 on each interface. . .
I would also shorten the masquerade rule - you only need the masquerade rule once, and don’t specify the source.
It’s enough (and automatically works for any future LAN segments you may create later) to simply say masquerade if out-interface = ether1. No more rules are required.
Can the Mikrotik itself ping to internet hosts?
bkuhn
April 24, 2015, 4:56am
6
Is your DHCP client on ether1 receiving an IP address from the Comcast modem?
You need to realign the antenna. Same hapened to me but I moved it left to right a lot until the signal was good. The antenna has lobes and you align them on that lobes. Also the signal must be identical ±3dbi. The link must have ~ -60dbi.
This box does not have WiFi radios.
ZeroByte:
It can bing the interwebs through port 1
Change your rules from this:
add action=masquerade chain=srcnat out-interface=ether1 src-address=10.160.250.0/24
add action=masquerade chain=srcnat out-interface=ether1 src-address=10.160.151.0/24
To just this:
Your config shows no rules for filter or masquerade.
Is this true? If you have filter or masquerade rules - try disabling them all and if that allows traffic to the Internet, then you can start to re-enable them one at a time until you find which one breaks stuff.
Changed that to:
Maybe my gateway is wrong here?
http://prntscr.com/6xmho7
In your posted configuration, I see this:
This is actually invalid.
.0 = the network prefix address, and is not a usable address in this case.
change these to be 10.160.250.1/24 and 10.160.251.1/24
I am getting this when I attempt to do that.
http://prntscr.com/6xn3ki
noyo
April 24, 2015, 4:01pm
15
Address: 10.160.250.0/24 - is a network
netmask: 24
I know this, ZeroByte told me to use 250.1/24 so I was replying to him.
Not in the network - that is the correct value for the network prefix.
Set the IP address.
I was working on this all weekend. Still nothing!
Screenshot: http://prntscr.com/6ysa5a
