help with upgrade
dears
i make an upgrade to my RB 433 AH with router OS V5.6 , the problem is after upgrading to the new OS the Router Board will not booting yet , can anyone help me ?
Sometimes after an upgrade it can take some time to reboot. If it doesn’t come back after about 10 minutes you can try to unplug it and plug it back in. If it still won’t boot then your best bet will is to do a netinstall.
