Help with Use Case
Hi.
Want advice on what products to support my use case.
I have my cable modem on one side of my house. Currently with a wifi router attached. I would
Like to get my signal to a barn which is about 100 meters away from the OTHER side of the house. I like the idea of the wireless wire but is there a piece of hardware that can ‘receive’ the signal from my in house WI-FI and then allow me to transfer to Ethernet so I can put into ‘wireless wire’ and blast across to barn.
TIA
Your best bet is find an ethernet jack on the side of the house facing the barn and mounting a wifi to wifi link using some of the 60Ghz products.
If your house is not wired, could you run something to the roof and mount a pole there to a Line of Sight to the Barn again using 60Ghz products?
Barring that can you bury some cable?
If you can wait MK is releasing Powerlines with Ethernet and wireless.
