I've finally decided to try and learn more about my CRS125-24G-1S-2HnD. I've had it for years, and I've never setup a guest wifi, or done any vlans.
I've had a look through several posts and videos.
Tutorials
https://www.youtube.com/channel/UC_vCR9AyLDxOlexICys6z4w
VLAN Post/Guide
I bought a book:
https://www.ispsupplies.com/RouterOS-by-Example-Book
I seem to have been successful in getting a WiFi VLAN working. I can get an IP, and get out to the internet on a seperate vlan and ssid.
However, the port based vlan (hard-wired ethernet) is eluding me.
I can get an IP, but, I can't route out to the internet.
My vlans conceptually are:
default vlan (came with the unit) - bridge-local
vlan 10 (seperate iot vlan for wifi) - bridge-iot-vlan10
vlan 30 - (trying out a port based vlan) - bridge-iot-ethernet-vlan30
See attached for giant verbose export (not sure if thats needed).
Also I'm fairly new to the code formatting features, so sorry if the txt option is bad.
Terse export:
dec/18/2019 13:31:07 by RouterOS 6.46
software id = CZB2-RAZR
model = CRS125-24G-1S-2HnD
serial number = 49C704FFF6FC
/interface bridge add name=bridge-iot-ethernet-vlan30
/interface bridge add comment="vlan 10 - iot - for wifi" fast-forward=no mtu=1500 name=bridge-iot-vlan10
/interface bridge add admin-mac=4C:5E:0C:91:61:A7 auto-mac=no comment="default bridge" fast-forward=no mtu=1500 name=bridge-local
/interface wireless set [ find default-name=wlan1 ] antenna-gain=13 band=2ghz-b/g/n country="united states" disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain mode=ap-bridge ssid=HideYoWIFI wireless-protocol=802.11 wps-mode=disabled
/interface ethernet set [ find default-name=ether1 ] name=ether1-gateway speed=100Mbps
/interface ethernet set [ find default-name=ether2 ] name=ether2-master-local speed=100Mbps
/interface ethernet set [ find default-name=ether3 ] name=ether3-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether4 ] name=ether4-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether5 ] name=ether5-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether6 ] name=ether6-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether7 ] name=ether7-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether8 ] name=ether8-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether9 ] name=ether9-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether10 ] name=ether10-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether11 ] name=ether11-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether12 ] name=ether12-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether13 ] name=ether13-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether14 ] name=ether14-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether15 ] name=ether15-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether16 ] name=ether16-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether17 ] name=ether17-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether18 ] name=ether18-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether19 ] name=ether19-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether20 ] name=ether20-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether21 ] name=ether21-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether22 ] name=ether22-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether23 ] name=ether23-slave-local speed=100Mbps
/interface ethernet set [ find default-name=ether24 ] name=ether24-slave-local speed=100Mbps
/interface ethernet set [ find default-name=sfp1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=sfp1-gateway
/interface vlan add interface=bridge-iot-ethernet-vlan30 name=vlan30 vlan-id=30
/interface ethernet switch set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether9-slave-local,ether10-slave-local
/interface list add exclude=dynamic name=discover
/interface list add name=mactel
/interface list add name=mac-winbox
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key= wpa2-pre-shared-key=
/interface wireless security-profiles add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=iot-profile supplicant-identity="" wpa2-pre-shared-key=
/interface wireless add comment="virtual ap for iot devices - assigned to vlan 10" disabled=no keepalive-frames=disabled mac-address=4E:5E:0C:91:61:BF master-interface=wlan1 multicast-buffering=disabled name=iot-wlan-24 security-profile=iot-profile ssid=JT-IOT-24 vlan-id=10 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface wireless manual-tx-power-table set iot-wlan-24 comment="virtual ap for iot devices - assigned to vlan 10"
/interface wireless nstreme set iot-wlan-24 comment="virtual ap for iot devices - assigned to vlan 10"
/interface vlan add interface=iot-wlan-24 name=vlan10 vlan-id=10
/ip ipsec proposal set [ find default=yes ] enc-algorithms=3des
/ip pool add name=default-dhcp ranges=192.168.88.10-192.168.88.254
/ip pool add name=dhcp_pool1 ranges=10.1.10.2-10.1.10.254
/ip pool add name=dhcp_pool2 ranges=10.1.30.2-10.1.30.254
/ip pool add name=dhcp_pool3 ranges=10.1.30.2-10.1.30.254
/ip dhcp-server add address-pool=default-dhcp authoritative=after-2sec-delay disabled=no interface=bridge-local lease-time=3d name=default
/ip dhcp-server add address-pool=dhcp_pool1 disabled=no interface=bridge-iot-vlan10 lease-time=3d name=dhcp1
/ip dhcp-server add address-pool=dhcp_pool3 disabled=no interface=vlan30 lease-time=3d name=dhcp2
/queue simple add disabled=yes name=John_PC_Queue packet-marks=John_Gaming_Packets priority=1/1 queue=pcq-upload-default/pcq-download-default
/snmp community set [ find default=yes ] addresses=0.0.0.0/0
/interface bridge port add bridge=bridge-local interface=ether2-master-local
/interface bridge port add bridge=bridge-local interface=wlan1
/interface bridge port add bridge=bridge-local interface=ether3-slave-local
/interface bridge port add bridge=bridge-local interface=ether4-slave-local
/interface bridge port add bridge=bridge-local interface=ether5-slave-local
/interface bridge port add bridge=bridge-local interface=ether6-slave-local
/interface bridge port add bridge=bridge-local interface=ether7-slave-local
/interface bridge port add bridge=bridge-local interface=ether8-slave-local
/interface bridge port add bridge=bridge-iot-ethernet-vlan30 interface=ether9-slave-local pvid=30
/interface bridge port add bridge=bridge-iot-ethernet-vlan30 interface=ether10-slave-local pvid=30
/interface bridge port add bridge=bridge-local interface=ether11-slave-local
/interface bridge port add bridge=bridge-local interface=ether12-slave-local
/interface bridge port add bridge=bridge-local interface=ether13-slave-local
/interface bridge port add bridge=bridge-local interface=ether14-slave-local
/interface bridge port add bridge=bridge-local interface=ether15-slave-local
/interface bridge port add bridge=bridge-local interface=ether16-slave-local
/interface bridge port add bridge=bridge-local interface=ether17-slave-local
/interface bridge port add bridge=bridge-local interface=ether18-slave-local
/interface bridge port add bridge=bridge-local interface=ether19-slave-local
/interface bridge port add bridge=bridge-local interface=ether20-slave-local
/interface bridge port add bridge=bridge-local interface=ether21-slave-local
/interface bridge port add bridge=bridge-local interface=ether22-slave-local
/interface bridge port add bridge=bridge-local interface=ether23-slave-local
/interface bridge port add bridge=bridge-local interface=ether24-slave-local
/interface bridge port add bridge=bridge-iot-vlan10 interface=iot-wlan-24 pvid=10
/interface bridge port add bridge=bridge-iot-vlan10 interface=vlan10 pvid=10
/interface bridge port add bridge=bridge-iot-ethernet-vlan30 interface=vlan30 pvid=30
/ip neighbor discovery-settings set discover-interface-list=discover
/interface ethernet switch egress-vlan-tag add tagged-ports=switch1-cpu vlan-id=30
/interface ethernet switch egress-vlan-translation add customer-vid=30 customer-vlan-format=untagged-or-tagged new-customer-vid=0 ports=ether9-slave-local,ether10-slave-local service-vlan-format=untagged-or-tagged
/interface ethernet switch ingress-vlan-translation add customer-vid=0 new-customer-vid=30 ports=ether9-slave-local,ether10-slave-local
/interface ethernet switch port set 0 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 1 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 2 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 3 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 4 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 5 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 6 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 7 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 8 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 9 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 10 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 11 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 12 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 13 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 14 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 15 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 16 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 17 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 18 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 19 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 20 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 21 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 22 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 23 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 24 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch port set 25 dscp-based-qos-dscp-to-dscp-mapping=no
/interface ethernet switch vlan add ports=ether9-slave-local,ether10-slave-local,switch1-cpu vlan-id=30
/interface list member add interface=wlan1 list=discover
/interface list member add interface=ether2-master-local list=discover
/interface list member add interface=ether3-slave-local list=discover
/interface list member add interface=ether4-slave-local list=discover
/interface list member add interface=ether5-slave-local list=discover
/interface list member add interface=ether6-slave-local list=discover
/interface list member add interface=ether7-slave-local list=discover
/interface list member add interface=ether8-slave-local list=discover
/interface list member add interface=ether9-slave-local list=discover
/interface list member add interface=ether10-slave-local list=discover
/interface list member add interface=ether11-slave-local list=discover
/interface list member add interface=ether12-slave-local list=discover
/interface list member add interface=ether13-slave-local list=discover
/interface list member add interface=ether14-slave-local list=discover
/interface list member add interface=ether15-slave-local list=discover
/interface list member add interface=ether16-slave-local list=discover
/interface list member add interface=ether17-slave-local list=discover
/interface list member add interface=ether18-slave-local list=discover
/interface list member add interface=ether19-slave-local list=discover
/interface list member add interface=ether20-slave-local list=discover
/interface list member add interface=ether21-slave-local list=discover
/interface list member add interface=ether22-slave-local list=discover
/interface list member add interface=ether23-slave-local list=discover
/interface list member add interface=ether24-slave-local list=discover
/interface list member add interface=bridge-local list=discover
/interface list member add list=discover
/interface list member add interface=ether2-master-local list=mactel
/interface list member add interface=ether3-slave-local list=mactel
/interface list member add interface=ether2-master-local list=mac-winbox
/interface list member add interface=ether4-slave-local list=mactel
/interface list member add interface=ether3-slave-local list=mac-winbox
/interface list member add interface=ether5-slave-local list=mactel
/interface list member add interface=ether4-slave-local list=mac-winbox
/interface list member add interface=ether6-slave-local list=mactel
/interface list member add interface=ether5-slave-local list=mac-winbox
/interface list member add interface=ether7-slave-local list=mactel
/interface list member add interface=ether6-slave-local list=mac-winbox
/interface list member add interface=ether8-slave-local list=mactel
/interface list member add interface=ether7-slave-local list=mac-winbox
/interface list member add interface=ether9-slave-local list=mactel
/interface list member add interface=ether8-slave-local list=mac-winbox
/interface list member add interface=ether20-slave-local list=mactel
/interface list member add interface=ether9-slave-local list=mac-winbox
/interface list member add interface=ether21-slave-local list=mactel
/interface list member add interface=ether20-slave-local list=mac-winbox
/interface list member add interface=ether22-slave-local list=mactel
/interface list member add interface=ether21-slave-local list=mac-winbox
/interface list member add interface=ether23-slave-local list=mactel
/interface list member add interface=ether22-slave-local list=mac-winbox
/interface list member add interface=ether24-slave-local list=mactel
/interface list member add interface=ether23-slave-local list=mac-winbox
/interface list member add interface=wlan1 list=mactel
/interface list member add interface=ether24-slave-local list=mac-winbox
/interface list member add interface=bridge-local list=mactel
/interface list member add interface=wlan1 list=mac-winbox
/interface list member add interface=bridge-local list=mac-winbox
/ip address add address=192.168.88.1/24 comment="default configuration" interface=wlan1 network=192.168.88.0
/ip address add address=10.1.10.1/24 comment="vlan10 for iot wifi" interface=bridge-iot-vlan10 network=10.1.10.0
/ip address add address=10.1.30.1/24 interface=vlan30 network=10.1.30.0
/ip dhcp-client add comment="default configuration" disabled=no interface=ether1-gateway
/ip dhcp-client add comment="default configuration" disabled=no interface=sfp1-gateway
/ip dhcp-server lease add address=192.168.88.254 client-id=1:0:4:4b:9:fc:ea mac-address=00:04:4B:09:FC:EA server=default
/ip dhcp-server lease add address=192.168.88.245 client-id=1:10:c3:7b:91:40:1d lease-time=521w3d mac-address=10:C3:7B:91:40:1D server=default
/ip dhcp-server lease add address=192.168.88.230 lease-time=521w3d mac-address=00:04:4B:09:FC:EA server=default
/ip dhcp-server lease add address=192.168.88.215 lease-time=521w3d mac-address=F4:F5:E8:18:5C:88 server=default
/ip dhcp-server lease add address=192.168.88.172 client-id=1:84:25:3f:3e:21:dc mac-address=84:25:3F:3E:21:DC server=default
/ip dhcp-server lease add address=192.168.88.167 client-id=ff:7b:91:40:1d:0:4:26:b5:d7:80:d8:82:11:dd:9c:6b:10:c3:7b:91:40:1d mac-address=10:C3:7B:91:40:1D server=default
/ip dhcp-server lease add address=192.168.88.166 client-id=1:74:bf:c0:75:a4:33 mac-address=74:BF:C0:75:A4:33 server=default
/ip dhcp-server network add address=10.1.10.0/24 dns-server=10.1.10.1,75.75.75.75,75.75.76.76 gateway=10.1.10.1
/ip dhcp-server network add address=10.1.30.0/24 gateway=10.1.30.1
/ip dhcp-server network add address=192.168.88.0/24 comment="default configuration" gateway=192.168.88.1
/ip dns set allow-remote-requests=yes
/ip dns static add address=192.168.88.1 name=router
/ip firewall address-list add address=192.168.88.0/24 list=DefaultVLAN
/ip firewall address-list add address=10.1.10.0/24 list=vlan10-iot-wifi
/ip firewall address-list add address=10.1.30.0/24 list=vlan30-iot-ethernet
/ip firewall filter add action=drop chain=input comment="Rule 1 - Input Chain - Drop Invalid - #LMB = Learn Mikrotik Book " connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="Rule 2 - Forward Chain - Drop Invalid - Learn Mikrotik Book" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="Rule 3 - Input Chain - Allow Default VLAN - Could be more restrictive for local router access - #LMB" src-address-list=DefaultVLAN
/ip firewall filter add action=accept chain=input comment="Rule 4 - Input Chain - Accept established - #LMB" connection-state=established
/ip firewall filter add action=drop chain=input comment="Rule 5 - Input Chain - Drop all others - #LMB"
/ip firewall filter add action=accept chain=forward comment="Rule 6 - Forward Chain - Allow new connections from Default VLAN - #LMB" connection-state=new src-address-list=DefaultVLAN
/ip firewall filter add action=accept chain=forward comment="Rule 10 - Forward Chain - Allow new connections from vlan 10 - iot wifi - Made by John T" connection-state=new src-address-list=vlan10-iot-wifi
/ip firewall filter add action=accept chain=forward comment="Rule 11 - Forward Chain - Allow new connections from vlan 30 - iot ethernet - Made by John T" connection-state=new src-address-list=vlan30-iot-ethernet
/ip firewall filter add action=accept chain=forward comment="Rule 7 - Forward Chain - Allow related connections through router - #LMB" connection-state=related
/ip firewall filter add action=accept chain=forward comment="Rule 8 - Forward Chain - Allow Established Connections through router - #LMB" connection-state=established
/ip firewall filter add action=drop chain=forward comment="Rule 9 - Forward Chain - Drop all other connections through router - #LMB"
/ip service set telnet disabled=yes
/ip service set ftp disabled=yes
/ip service set www address=192.168.88.0/24
/ip service set ssh address=192.168.88.0/24
/ip service set www-ssl address=192.168.88.0/24 disabled=no
/ip service set api address=192.168.88.0/24
/ip service set winbox address=192.168.88.0/24
/ip service set api-ssl address=192.168.88.0/24
/ip ssh set allow-none-crypto=yes forwarding-enabled=remote
/ip upnp interfaces add interface=ether1-gateway type=external
/ip upnp interfaces add interface=bridge-local type=internal
/lcd set time-interval=weekly
/system clock set time-zone-autodetect=no time-zone-name=America/New_York
/system identity set name=CRS125-24G-1S-2HnD
/system leds set 0 interface=wlan1
/system leds set 1 interface=sfp1-gateway leds=""
/system ntp client set enabled=yes server-dns-names=us.pool.ntp.org,pool.ntp.org
/tool mac-server set allowed-interface-list=mactel
/tool mac-server mac-winbox set allowed-interface-list=mac-winbox
verbose-export-config-post.rsc (118 KB)
