Hello to Everyone!! ![]()
I have a MikroTik LHG LTE Device and i use a SIM to connect to internet.
I have a big problem, the isp nat my ip so i can’t connect outside the lan, but i have bought a VPN service so i can connect my mobile device and my MikroTik in the same vpn to see the device inside my lan network and use for example my security camera.
The problem is that i don’t know how can i set the MikroTik to connect to VPN and how can do Port Forwarding…
The VPN Service use a variety of protocol.. from L2TP-IPsec to OpenVPN etc…
Thanks a lot for all your help
Hi
The vpn is just another way to “exit to the world”, in general it’s not an entry into your network. When you VPN you’ll usually share some internet routable ip with other users of that VPN service.
Maybe your vpn can do some forwarding for you, check with them as the configuration will need to be done at their end, not yours.
Cheers
Thanks a lot for your reply.
I have found this in the vpn site:
- Do you provide public dynamic dedicated IPs?
Yes, connecting with OpenVPN TUN + UDP + 1194 for locations Sweden, Norway, Germany - Frankfurt 1, Netherlands 1, Ukraine, Switzerland, United Kingdom - London 2, France - Paris, USA - Buffalo and USA - Los Angeles
but i don’t know how to do..
Regards
Thanks a lot!!! i have solved the problem using pfsense
