Hi everyone , my name is Claudio and i’m here to ask for your precious help.
I’m getting crazy to figure out how i have to set my configuration. My case and needed are the following:
ISP 1 , Starlink, with bypassed original modem, provide an internet connection via dynamic ip
ISP 2, Wind, lte connection using a 4g sim, dynamic ip too
i have to set 2 different lan, LAN1 for eth port 2 e 3 and LAN2 for eth port 4 e 5
LAN1 device can use both isp connection ( not load balancing, just simple backup connection if ISP1 fall)
LAN2 MUST use ONLY ISP2 , and had to disconnect when ISP2 fall without reconnect till it comes up again
I would like to have the lan IP like 192.168.2.0 and 192.168.3.0 but it’s not important.
Can someone show me how to do this? with command line or GUI it’s the same, but i prefer gui. Otherwise can someone export me a configuration file ?
My hardware is a Mikrotik chateau 4g lte modem , RBD53G-5HacD2HnD routerboard , winbox 7.1beta5 firmware
