I am a newbie in Mikrotik scritpting and just learning the ropes right now. I have a script that works correctly but I need to put a where statement in this script to not run where it detects an agent remote id field.
the current script is :
I would like to put where statement on this script to not run when it detects the agent-remote-id is not Null. But I am not sure where to put this where statement at..
Thank you . I will run this.
I need to learn Mikrotik Scripting. Does anyone offer any scripting courses or something or any video tutorials? I feel like I don't know how any of this works.
You sure?
Did you notice that I have changed very few things?
Your script was almost all written correctly…
Often other scripts that I correct are monstrous…
You are on your way.
I didn’t take any courses, I learned easily because I had already programmed in the past on other languages…
Unfortunately I don’t know what to recommend…
