I have a (beloved) RB5009 that is working wonderfully (export below) and recently got a laptop and installed Fedora Auroro linux on it to play and learn (and it’s totally cool!).
I set up a Wireguard connection between the linux PC and the RB5009 and have made great progress. Each device can ping each other on the 10.10.100.x network.
The RB5009 is also connected via wireguard to a number of other MT devices which all exist in the 10.10.100.x network. I can ping from the linux PC to any of those devices (e.g., 10.10.100.30, 10.10.100.40, etc.).
Each of those remote MT devices has a 192.168.x.x network on their LAN side.
My goal, which I have been unable to achieve as of yet, is for the WG connection from the linux PC to reach all the other WG-connected LANs at their local 192.168.x.x networks.
My suspicion is that the problem is either routing or firewall (let’s see if I’m on the right track).
Another big problem is that whenever the WG connection is active on the laptop, I lose internet connectivity that otherwise is made available via the laptop’s wifi connection. I don’t know if a default route changes, or something else.
Can someone please take a look?
Here is the WG config on the linux PC, extracted by:
>sudo cat /etc/NetworkManager/system-connections/212-RB5009.nmconnection
[connection]
id=212-RB5009
uuid=519c54b9-bc72-40cd-8b55-ecdcd1594bc5
type=wireguard
autoconnect=false
interface-name=wg
[wireguard]
listen-port=13340
private-key=KDUXH-------
[wireguard-peer.xx27--------]
endpoint=<HOST>.dyndns.org:51820
persistent-keepalive=40
allowed-ips=10.10.100.0/24;192.168.0.0/16;
[ipv4]
address1=10.10.100.101/24
dns=1.1.1.1;
gateway=10.10.100.1
method=manual
[ipv6]
addr-gen-mode=stable-privacy
method=ignore
And here is the RB5009 export:
# 2025-11-02 06:23:23 by RouterOS 7.19.3
# software id = 2KBD-7ZZB
# model = RB5009UPr+S+
# serial number = HDA0
add admin-mac=18:FD:74:CF:7F:5D auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] comment=WAN poe-out=off
set [ find default-name=ether2 ] comment=hAPax3-Downstairs poe-out=off
set [ find default-name=ether3 ] comment="JRS PC port 3" poe-out=off
set [ find default-name=ether4 ] comment=hAPax3-Upstairs poe-out=off
set [ find default-name=ether5 ] comment=<empty> poe-out=off
set [ find default-name=ether6 ] comment="MOCA adapter" poe-out=off
set [ find default-name=ether7 ] comment=OffBridge poe-out=off
set [ find default-name=ether8 ] comment=BI-Server poe-out=off
set [ find default-name=sfp-sfpplus1 ] comment=CSS326
/interface wireguard
add listen-port=51820 mtu=1420 name=212-Wireguard private-key=\
"WIPjFC5--------A="
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=MANAGE
add name=DHCPdisabled
add name=TRUSTED
add name=IoT-Cameras
/iot lora servers
add address=eu.mikrotik.thethings.industries name=TTN-EU protocol=UDP
add address=us.mikrotik.thethings.industries name=TTN-US protocol=UDP
add address=eu1.cloud.thethings.industries name="TTS Cloud (eu1)" protocol=\
UDP
add address=nam1.cloud.thethings.industries name="TTS Cloud (nam1)" protocol=\
UDP
add address=au1.cloud.thethings.industries name="TTS Cloud (au1)" protocol=\
UDP
add address=eu1.cloud.thethings.network name="TTN V3 (eu1)" protocol=UDP
add address=nam1.cloud.thethings.network name="TTN V3 (nam1)" protocol=UDP
add address=au1.cloud.thethings.network name="TTN V3 (au1)" protocol=UDP
/iot mqtt brokers
add address=192.168.0.103 client-id=192.168.2.2 name=HA password=XXXXX \
username=mqtt
add address=192.168.0.162 auto-connect=yes name="Home Assistant" password=\
XXXXX username=mqtt
add name=192.168.2.100-200 ranges=192.168.2.100-192.168.2.200
add comment=offbridge-dhcp-server name=offbridge-dhcp-server ranges=\
192.168.55.101-192.168.55.200
add address-pool=192.168.2.100-200 interface=bridge lease-time=3d name=defconf
add address-pool=offbridge-dhcp-server comment=offbridge-dhcp-server \
interface=ether7 name=offbridge-dhcp-server
/ip smb users
/system logging action
set 3 remote=192.168.2.22
add name=logserver remote=192.168.0.112 remote-port=51400 target=remote
add email-to=jXXXXX@domain.com name=email target=email
add disk-file-name=UPSLOG name=diskups target=disk
/container config
set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/interface bridge filter
add action=drop chain=forward disabled=yes dst-port=67-68 in-interface-list=\
DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Forward \
mac-protocol=ip out-interface-list=DHCPdisabled src-port=67-68
add action=drop chain=input disabled=yes dst-port=67-68 in-interface-list=\
DHCPdisabled ip-protocol=udp log-prefix=Bridge-Filter-Input mac-protocol=\
ip src-port=67-68
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2 \
internal-path-cost=10 path-cost=10
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4 \
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 \
add bridge=bridge interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge interface=sfp-sfpplus1
set udp-timeout=10s
set discover-interface-list=TRUSTED
/ipv6 settings
set accept-redirects=no accept-router-advertisements=no disable-ipv6=yes \
forward=no max-neighbor-entries=8192 soft-max-neighbor-entries=8191
add disabled=yes interface=bridge list=MANAGE
add disabled=yes interface=ether1 list=MANAGE
add interface=212-Wireguard list=LAN
add disabled=yes interface=212-Wireguard list=MANAGE
add interface=212-Wireguard list=DHCPdisabled
add comment=OffBridge interface=ether7 list=LAN
add disabled=yes interface=ether7 list=MANAGE
add interface=bridge list=TRUSTED
add interface=ether7 list=TRUSTED
add interface=212-Wireguard list=TRUSTED
/interface ovpn-server server
add mac-address=FE:B2:B3:FE:59:72 name=ovpn-server1
/interface wireguard peers
add allowed-address=10.10.100.8/32 comment="JRS Laptop" interface=\
212-Wireguard name=jrs-laptop public-key=\
"b9iyIPXw9MQIGo852yC/xxxxxx="
add allowed-address=\
10.10.100.2/32,192.168.88.0/24,10.10.100.40/32,192.168.40.0/24 comment=\
371 endpoint-address=XXXXX.dyndns.org endpoint-port=52820 interface=\
212-Wireguard name=371 persistent-keepalive=40s public-key=\
"xxxxxx="
add allowed-address=10.10.100.9/32 comment="JRS iPhone" interface=\
212-Wireguard name=jrs-iphone public-key=\
"PypzufC5QJLUMgJCHEmbjQYbmC+ZS2Kk4+xxxxxx="
add allowed-address=10.10.100.12/32,192.168.20.0/24 comment=629 \
endpoint-address=XXXXX.dyndns.org endpoint-port=51821 interface=\
212-Wireguard name=629 persistent-keepalive=40s public-key=\
"xxxxx="
add allowed-address=10.10.100.60/32,192.168.1.0/24 comment=255 \
endpoint-address=XXXXX.dyndns.org endpoint-port=51835 interface=\
212-Wireguard name=255 persistent-keepalive=40s public-key=\
"xxxxx+r9bzZ0aWPK0PMwbRc="
add allowed-address=10.10.100.30/32,192.168.30.1/24 comment=76 \
endpoint-address=XXXXX.dyndns.org endpoint-port=51830 interface=\
212-Wireguard name=76 persistent-keepalive=40s public-key=\
"xxxx="
add allowed-address=10.10.90.0/24 comment="BI PC WG APP" endpoint-port=51820 \
interface=212-Wireguard name=peer8 public-key=\
"R5SjZucQPhyu5CQyXLvxf/xxxxx="
add allowed-address=10.10.100.1/32,192.168.2.2/24 comment=\
"212 (local, just for reference); 192.168.2.2" disabled=yes \
endpoint-address=XXXXX.dyndns.org endpoint-port=51820 interface=\
212-Wireguard name=peer9 public-key=\
"xxxxx/op1OqXrW4Ds="
add allowed-address=10.10.100.100/32 comment="JRS Laptop 201" disabled=yes \
interface=212-Wireguard name=peer10 public-key=\
"QJCXZaf5K/xxxx="
add allowed-address=10.10.100.101/32 endpoint-port=51840 interface=\
212-Wireguard name=peer11 public-key=\
"N/t6/86S/xxxx="
add allowed-address=10.10.100.70/32,192.168.70.0/24 comment=125 \
endpoint-address=XXXXX.dyndns.org endpoint-port=51870 interface=\
212-Wireguard name=125 persistent-keepalive=40s public-key=\
"xxxx="
add allowed-address=10.10.100.99/32,192.168.2.0/24 comment="JRS Laptop 2023" \
interface=212-Wireguard name=peer13 private-key=\
"ED8Ig6UntTB7Kg+xxxx//vOc9p2Q=" public-key=\
"w9XFUjODaOIOQbCeMVJ+xxxxx="
add allowed-address=10.10.100.53/32,192.168.0.0/24 client-listen-port=51840 \
comment="WG Proxmox Win11" endpoint-address=XXXXX.dyndns.org \
endpoint-port=51844 interface=*12 name=peer15 public-key=\
"Wut4NWWjMvqM+8BNw0IP+xxxx="
add allowed-address=10.10.100.15/32 comment=355-AX3 disabled=yes \
endpoint-address=10.0.0.1 endpoint-port=51860 interface=212-Wireguard \
name=355-ax3 persistent-keepalive=40s public-key=\
"C6fhu5+xxxx/OH756yD08OtpEw54Qql3LZ04="
add allowed-address=10.10.100.10/32 comment="T Laptop" interface=\
212-Wireguard name=t-laptop public-key=\
"xxxx+vjrp81mL+itsBc="
add allowed-address=10.10.100.80/32,192.168.80.1/24,10.72.0.0/16 comment=729 \
endpoint-address=xxxx.dyndns.org endpoint-port=51880 interface=\
212-Wireguard name=729 persistent-keepalive=40s public-key=\
"xxx/xxx+DzjqQ4t0CQ="
add allowed-address=10.10.100.81/32 comment=hex-lab endpoint-address=\
192.168.2.192 endpoint-port=51881 interface=212-Wireguard name=peer19 \
"U/xxxx/+xxx/y0="
add allowed-address=10.10.100.50/32,192.168.0.0/24,192.168.5.0/24 comment=355 \
endpoint-address=XXXXX.dyndns.org endpoint-port=51833 interface=\
212-Wireguard name=355 persistent-keepalive=40s public-key=\
"Q8CPJm+/xxx="
add allowed-address=10.10.100.101/32 comment=Aurora-laptop interface=\
212-Wireguard name=Aurora-laptop private-key=\
"KDUXHH4-----" public-key=\
"rKKCAbPpb-----"
add address=192.168.2.2/24 comment=defconf interface=bridge network=\
192.168.2.0
add address=10.10.100.1/24 interface=212-Wireguard network=10.10.100.0
add address=192.168.55.1/24 interface=ether7 network=192.168.55.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server alert
add alert-timeout=12h disabled=no interface=bridge on-alert="/system script ad\
d name=rogue-dhcp source=\94:log warning message=\\\94Rogue DHCP server de\
tected!\\\94\94"
add alert-timeout=30m interface=bridge on-alert=rogue-dhcp
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.2 gateway=\
192.168.2.2 netmask=24
add address=192.168.55.0/24 dns-server=1.1.1.1 gateway=192.168.55.1 netmask=\
24
set allow-remote-requests=yes cache-max-ttl=3d cache-size=10000KiB servers=\
9.9.9.9,1.1.1.1,8.8.4.4
/ip dns static
add address=192.168.2.8 name=212-rb5009.212.local type=A
add address=192.168.2.2 name=RB5009.212.local ttl=9w6d10h40m type=A
add address=10.10.100.1 name=212.10.10.100.1.local ttl=9w6d10h40m type=A
add address=192.168.2.100 comment="automatic-from-comment (magic comment)" \
name=TV15.212.local ttl=1h type=A
add address=192.168.2.121 comment="automatic-from-comment (magic comment)" \
name="Ipad SRN.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.138 comment="automatic-from-comment (magic comment)" \
name=MFCL3770CDW.212.local ttl=9w6d10h40m type=A
add address=192.168.2.141 comment="automatic-from-comment (magic comment)" \
name="JRS iPhone.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.109 comment="automatic-from-comment (magic comment)" \
name="Vizio on 15.212.local" ttl=9w6d10h40m type=A
add address=192.168.2.122 comment="automatic-from-comment (magic comment)" \
name=Homepod.212.local ttl=9w6d10h40m type=A
add address=192.168.2.199 comment="automatic-from-comment (magic comment)" \
name=Playstation.212.local ttl=9w6d10h40m type=A
add address=192.168.2.142 comment="automatic-from-comment (magic comment)" \
name=SRNAppleWatch.212.local ttl=9w6d10h40m type=A
add address=192.168.2.22 name=JRS-PC.212.local type=A
add address=192.168.2.102 comment="automatic-from-dhcp (magic comment)" name=\
Master-Bedroom.212.local ttl=1h40m type=A
add address=192.168.2.103 comment="automatic-from-dhcp (magic comment)" name=\
Family-Room.212.local ttl=1h40m type=A
add address=192.168.2.138 comment="automatic-from-dhcp (magic comment)" name=\
MFC-L3770.212.local ttl=1h40m type=A
add address=192.168.2.147 comment="automatic-from-dhcp (magic comment)" name=\
212LR.212.local ttl=1h40m type=A
add address=192.168.2.191 comment="automatic-from-dhcp (magic comment)" name=\
SRNOffice.212.local ttl=1h40m type=A
add address=192.168.2.128 comment="automatic-from-dhcp (magic comment)" name=\
212MBR.212.local ttl=1h40m type=A
add address=192.168.2.200 comment="automatic-from-dhcp (magic comment)" name=\
HarmonyHub.212.local ttl=1h40m type=A
add address=192.168.2.124 comment="automatic-from-dhcp (magic comment)" name=\
BRW2C6FC95FBCEB.212.local ttl=1h40m type=A
add address=192.168.2.173 comment="automatic-from-dhcp (magic comment)" name=\
NC-LT-SN20.212.local ttl=1h40m type=A
add address=192.168.2.137 comment="automatic-from-dhcp (magic comment)" name=\
tasmota-E37677-5751.212.local ttl=1h40m type=A
add address=192.168.2.117 comment="automatic-from-dhcp (magic comment)" name=\
BRNB4220095598A.212.local ttl=1h40m type=A
add address=192.168.2.127 comment="automatic-from-dhcp (magic comment)" name=\
Debian.212.local ttl=1h40m type=A
add address=192.168.2.110 comment="automatic-from-dhcp (magic comment)" name=\
JRS-Laptop-2023.212.local ttl=1h40m type=A
add address=192.168.2.108 comment="automatic-from-dhcp (magic comment)" name=\
0005CD193C07.212.local ttl=1h40m type=A
add address=69.202.199.148 name=XXXXX.dyndns.org type=A
add address=192.168.2.2 comment=router.212.internal name=router.212.internal \
type=A
add address=10.10.100.80 comment=729router.internal name=729router.internal \
type=A
add address=192.168.2.22 comment=jrspc name=jrspc.212.internal type=A
/ip firewall address-list
add address=XXXXX.dyndns.org list=dynamic-WANIP
add address=192.168.0.0/16 list=Authorized
add address=10.10.100.0/24 list=Authorized
add address=XXXXX.dyndns.org list=XXXXX
add address=hda08a4mazh.sn.mynetname.net list=PublicIP
add action=log chain=input comment="Port 53 Log" connection-state=new \
disabled=yes dst-port=53 log=yes log-prefix=TCP-53 protocol=tcp
established,related,untracked
invalid
add action=accept chain=input comment="Loopback allow" dst-address=127.0.0.1
add action=accept chain=input comment="Allow incoming WG connections" \
dst-port=51820 protocol=udp
add action=drop chain=input comment="DROP DHCP on DHCPdisabled" disabled=yes \
dst-port=67-68 in-interface-list=DHCPdisabled log=yes protocol=udp \
src-port=67-68
add action=accept chain=input comment="Allow GRE for EoIP" disabled=yes log=\
yes protocol=gre
add action=accept chain=input comment="Allow Authorized" src-address-list=\
Authorized
add action=accept chain=input comment="Allow LAN" in-interface-list=LAN
add action=drop chain=input comment="drop all else" log-prefix=drop-all-else
connection-state=invalid
add action=accept chain=forward comment="Allow WG to subnet" dst-address=\
192.168.2.0/24 in-interface=212-Wireguard
add action=accept chain=forward comment="Allow all traffic out WG iface" \
out-interface=212-Wireguard
add action=accept chain=forward comment="Allows cross peer subnet traffic" \
in-interface=212-Wireguard out-interface=212-Wireguard
add action=accept chain=forward comment="Allow LAN to WAN" disabled=yes \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat disabled=yes
/ip firewall mangle
add action=mark-connection chain=prerouting comment=\
"Mark connection for hairpin" disabled=yes dst-address-list=dynamic-WANIP \
log=yes new-connection-mark="Hairpin NAT" src-address=192.168.2.0/24
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark=\
"Hairpin NAT" dst-address=192.168.2.0/24 src-address=192.168.2.0/24
add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:81 \
dst-address-list=XXXXX dst-port=81 log-prefix=\
"NAT FW destination XXXXX port 81" protocol=tcp to-addresses=\
192.168.0.101 to-ports=81
add action=dst-nat chain=dstnat comment=XXXXX.dyndns.org:8123 \
dst-address-list=XXXXX dst-port=8123 protocol=tcp to-addresses=\
192.168.0.162 to-ports=8123
add action=masquerade chain=srcnat comment="NEW defconf: masquerade" \
add action=dst-nat chain=dstnat dst-address-list=dynamic-WANIP dst-port=8123 \
protocol=tcp to-addresses=192.168.2.176
"Hairpin NAT" disabled=yes dst-address=192.168.2.0/24 src-address=\
192.168.2.0/24
disabled=yes out-interface-list=WAN
add action=dst-nat chain=dstnat disabled=yes dst-address-list=dynamic-WANIP \
dst-port=8123 protocol=tcp to-addresses=192.168.2.176
dst-port=5911 log=yes protocol=tcp to-addresses=192.168.2.139
add action=dst-nat chain=dstnat disabled=yes dst-port=51833 protocol=udp \
to-addresses=192.168.2.50
192.168.2.0/24
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d \
wed=0s-1d
add disabled=yes distance=1 dst-address=192.168.5.0/24 gateway=212-Wireguard \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
target-scope=10
add comment=355 disabled=no distance=1 dst-address=192.168.0.0/24 gateway=\
212-Wireguard pref-src="" routing-table=main scope=30 \
suppress-hw-offload=no target-scope=10
add comment=255 disabled=no distance=1 dst-address=192.168.1.0/24 gateway=\
add comment=355-Cameras disabled=no distance=1 dst-address=192.168.5.0/24 \
gateway=212-Wireguard pref-src="" routing-table=main scope=30 \
add comment=629 disabled=no distance=1 dst-address=192.168.20.0/24 gateway=\
add disabled=no distance=1 dst-address=192.168.60.0/24 gateway=192.168.2.8 \
target-scope=10
add comment=76 disabled=no distance=1 dst-address=192.168.30.0/24 gateway=\
add comment=371 disabled=no distance=1 dst-address=192.168.40.0/24 gateway=\
add comment=125 disabled=no distance=1 dst-address=192.168.70.0/24 gateway=\
add disabled=yes distance=1 dst-address=10.0.0.0/24 gateway=192.168.2.5 \
target-scope=10
add comment="TEMP -- REMOVE THIS WHEN 729 AX3 is moved" disabled=yes \
distance=1 dst-address=172.16.0.0/16 gateway=192.168.2.192 routing-table=\
main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=10.0.0.0/8 gateway=212-Wireguard \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=yes distance=1 dst-address=192.168.4.0/24 gateway=10.10.100.80 \
add comment=729 disabled=no distance=1 dst-address=192.168.80.0/24 gateway=\
212-Wireguard routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=yes distance=1 dst-address=10.21.0.0/16 gateway=ether5 \
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set www-ssl disabled=no
set api disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ip ssh
set always-allow-password-login=yes forwarding-enabled=both
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=212-RB5009
/system logging
set 0 topics=info,!wireguard,!dhcp
add topics=account
add topics=watchdog
add action=logserver prefix="XXXXXH MikroTik" topics=hotspot
add action=logserver prefix="XXXXXH MikroTik" topics=\
!debug,!packet,!snmp
add action=remote disabled=yes prefix=192.168.2.2 topics=info
add action=remote disabled=yes topics=ups
add topics=ups
add disabled=yes topics=dns
add topics=firewall
add action=diskups regex="^\\[UPS\\]:" topics=script
add action=disk topics=watchdog
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=216.239.35.4
add address=104.16.132.229
/system ups
add name=ups1 port=usbhid1
/system watchdog
set auto-send-supout=yes ping-start-after-boot=10m ping-timeout=10m \
send-email-to=jXXXXX@domain.com watch-address=1.1.1.1
/tool e-mail
set from=jXXXXX@domain.com password="bpxk rxgz xxx" port=587 \
server=smtp.gmail.com tls=starttls user=<xxxx>@gmail.com
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool romon
set enabled=yes
