Help with WPA & WPA2 PSK (AR5211 x AR5213)
Hi …
Is there any special reason for an OEM AR5211 based card on a 3.27 ROS working as station on 2.4b mode not connect to a 3.27 ROS that have an AR5213 (UBNT SR2) when running WPA / WPA2?
Using default security profile they connect.
The station with ROS 3.27 + OEM AR5211 connects ok using WPA or WPA2 if the AP is not MT with AR5213. Works with a Netgear AP, Level One AP and MT 3.27 + OEM AR5211 AP.
On the other side, ROS 3.27 with SR2 as AP accepts B mode clients with WPA or WPA2 enabled (several chipsets, including one with AR5211 from an old Linksys A/B PCMCIA adapter).
Any ideas?
Regards;
