help!!!
can someone recommend a Mikrotik router that i can use in a building with 50 people and i can also time users and their session will expire when the allocated time expires.
Thank you.
Do you need only a central ethernet router for management, or you also require wifi access points?
Do you plan to only use hotspot for accounting, or also use firewall, bandwidth limitation and such?
will you use a switch, or you need to have many ports on the router itself, how many?
