help
hi everyone
I have rb2011 series and i need to download dude npk file for it can any one help me with that which file should i download
kadhim09,
As described on Dude v6 installation page:
System requirements for server package
RouterOS:
v6.34rc13 or newer
Hardware:
Tile - CCR series hardware
ARM - RB3011
mmips - hEX (RB750Gr3)
RouterOS x86 installations
RouterOS CHR environment
Your device can be used as a Dude agent.
Thank you!
You can’t. It’s not supported.
so what is supported
why didn’t you do dude on x86,easy for your router will be save CPU :slight_smile:
@kadhim09
