Help !!!
I have a new problem, but with another equipment,
it throws the following error to me:
RouterBOOT booter 2.6
RouterBoard 112
CPU frequency:
Press any key within 2 seconds to enter setup..
trying bootp protocol… OK Got IP address:
172.16.0.5 resolved mac address 00:00:39:FF:F0:32 transfer started
… transfer ok, time=2.20s setting up elf image…
OK jumping to kernel code Kernel panic - not syncing: VFS: Unable to
mount root fs on
unknown-block(0,0)
use a dedicated PC
I need to use version 3.0 beta5 and she installs it from:
http://www.mikrotik.com/download.html
thanks :cry:
Make sure you have the latest version of netinstall.
Use the one listed on the RB down load section.
Craig
