help
hi I have an ldf 5 and I wonder if there is a way to reset by the PoE injector
Do you see red “RES” by the “small circle” on the picture? It is RESET hole showed. You need to use this switch to reset device.
Do you imagine that anyone could reset any device on the mast just with power on/off procedure?
I need to know which wire is responsible for resting, so I can be used it form PoE injector
None:
https://wiki.mikrotik.com/wiki/Manual:PoE-In
MikroTik products don’t have “reset from PoE injector” functions.
