HELP!
my mikrotik haplite and my d link switch hub are connected.
however one of my client pc connected in a switch hub are unable to connect to the internet unless if i rebooted the mikrotik by replugging the router. Any help?
  1. Next time try to do more specific with the title of your post.
  2. You tried to connect it directly to Mikrotik?
  3. The drivers of the NIC are updated?
  4. What version of ROS are you using?
Regards.
