i got mikrotik RB1100AH x2 it powers on but doesnt beep
Sounds to me like you don’t have a major problem…is beeping disabled (not sure if possible)?
And is that your only problem?
for now yes could u guide me on how to check if beeping is disable
From the wiki:
https://wiki.mikrotik.com/wiki/Silent_boot
https://wiki.mikrotik.com/wiki/Manual:RouterBOARD_settings
And the helpfiles:
https://help.mikrotik.com/docs/display/ROS/RouterBOOT#RouterBOOT-Configuration
https://help.mikrotik.com/docs/display/ROS/RouterBOARD#RouterBOARD-Settings
Check for silent boot.
Most probably is that I’d not beeping it is bricked for some unknown reason. Try use netinstall.
https://wiki.mikrotik.com/wiki/Manual:Netinstall
Regards.
