Hello friendly I am in need of his help forgive if not I write well it is that I do not dominate the English very much I hope to surrender to get along well. I have a rb433ah with 45 customers I emit with one antenna 15 +'s omni a card minipci xr2 my customers get connected by means of hotspot. My customers to receive the sign have teams ap tplink501g. The problem is the fact that with some users once in a while they can get connected, for times put salt in them the page of the login and another times not the utmost the fact that I have seen on-line users comes from 25 I if another user wants to get connected no longer believe you can however much his team represents it in my MK. Also when I see the log aprece provided that such user gets connected and he disconnects at every moment sometimes followed and another times for some 10min, 15min another problem is the fact that sometimes they enter direct no longer the page comes out of their logeo as you appeared to them. Another problem that also I have is with the msn, the users that go in with logeo if it is that the page comes out of his login, are in the msn for 4 min and next they close everything to to them you ask them for than himself logeen again.
No puedo escribir nada en el terminal aqui una imagen de como se ve el terminal no se si andara mal. Esto es normal en el terminal de que se vea asi?
I can not write anything in the terminal here an image of as the terminal no is seen himself if you will walk bad . Is this normal in the terminal of that you see yourself that way?
