help
there are my pic.
i get two ISP but out 1 lan without load balance
ip from 1to 127 take internet from the first
ip from 128to 255 take theinternet from the sec.
but the is something wrong that i don’t know
you can see and told me
What exactly is the problem? The NAT counters are going up like they should, so that means it should be working. Without more description of what you are seeing, it’s impossible to help. Also /export and /print wrapped in code brackets are almost always more helpful than screenshots. Screenshots never tell you everything that you need to know.
