help
hi all
How do I do as it is shown in the diagram.
i need help please
thanks
help please
what part are you stuck on?
dear i want to assign and isolate each public ip to client router . for example
1.1.1.51 in R1 .
have you looked at the manual - http://wiki.mikrotik.com/wiki/Manual:TOC
Thanks for the reply, but what exactly is the topic in the link?
up,
Connect your R1-R5 routers via switch instead of router.
HTH,
thanks but i want to do it via router .
All addresses (1.1.1.49 - .54) are in the same subnet, so there is no need for routing.
Why do you want to connect R1-R5 via router?
Regards,
ok how can i limit the IP: 1.1.1.50 and send it to Clint like R1 ?
i want to send one public Ip with 1mpbs to R1
Configure your Mikrotik router as a bridge:
http://wiki.mikrotik.com/wiki/Manual:Interface/Bridge
Use firewall to allow traffic from/to specific IP address (e.g. 1.1.1.50) only via one ethernet interface.
To limit bandwidth per IP address use simple queues:
http://wiki.mikrotik.com/wiki/Manual:Queue#Simple_Queues
HTH,
Do you think that the way the bridge is the ideal way for this issue?
^ your name oxid, makes the hair on my back tingle
why say that ?
up,
up,
ok thanks
but Do you think that the way the bridge is the ideal way for this issue? and can i configure firewall to do what you say?
regards
sorry i mean how can i configure firewall to do what you said?
up,
