HELP!
Hi folks.
I need to know which Mikrotik router I should have bought to run a small home WIFI network. I need to support a couple computers, an iPad, a Kindle, an AppleTV, at least 120 Mbps d/l speed etc.
I just mistakenly purchased an rb2011uas-2hnd through my local distributor, after reading:
http://www.xagyl.com/store/product.php?productid=16655&cat=&page=2
I thought I would receive something suitable for use as a home WIFI router, something in a box with a power supply etc. What I received was just a circuit board!
What do I do with this?
If I need to return it, what should I be ordering instead to get something more user friendly, something at least in some sort of enclosure?
To explain further, I am blind, so I only know what is described on that web page in text. That’s what my screen reading software told me about the product. If a picture shows that this particular model is just a circuit board, I had no way of knowing that.
So, can I get some sort of mounting hardware, power supply, software etc. for this, or should I just return it and buy a different model?
Please advise.
Chris
UPDATE: I’m pretty sure I should have gone with a RB2011UiAS-2HnD-IN … the wiki about product naming conventions helped.
So, once I return this board and order the right unit, I should be fine.
Yes, the RB2011UiAS-2HnD-IN is the one you want. It comes in a case and with a power supply. There are also a handful of other SOHO routers that have less features (you may have already looked at them). They can be found at http://routerboard.com/ under the “Wireless for home and office” heading.
