Hello everyone, today I received my new router SXT G-2HnD and I tried to make some settings, but it was quite difficult to get. Then I decided to reset the configuration by winbos tool, but I noticed that some links and bridges remained and I decided to delete them. Now no relation with my new router, I try manually to reset , but no result, please for some advice, which will be very valuable to me
Run Winbox, hit “…” button and look for your router. Connect to your router.
i am also face this problem plz help in this matter. the router didnot respond and not connect any pc laptop and winbox also plz give me advice how to connect this and reset it.
but router not connect to pc
Factor reset using the reset button.
With the power unplugged, hold the reset button, then plugin power and keep holding the reset button for 15 seconds. Then release.. This should bring it back to factory defaults.
