Helping newbie on VLAN set-up with M4100 and Mikrotik router
(Cross-posting this from Netgear forum in case somebody here can help).
I wonder if somebody would be kind enough to give some top level pointers about how I go about setting up routing/VLAN for the following scenario. My knowledge of VLAN on managed switches is limited. The setup is:
Internet - Mikrotik router - Netgear M4100 switch - Mikrotik access point
The router is configured with LAN 192.168.88.0/24 and VLAN10 10.0.0.0/24. The access point is configured with no tagging on the LAN (private) Wi-Fi interface and VLAN10 on a virtual guest interface. Connecting to the private LAN via the access point works fine. However, try to connect via the guest interface and the client doesn’t get an IP. Remove the VLAN tagging on that interface OR plugging it directly into the Mikrotik router works fine (client gets 192.168.88.0/24 or 10.0.0.0/24 respectively).
So… VLAN routing I’m guessing needs setting up on the switch. The Netgear switch when it receives a broadcast on VLAN 10 doesn’t know where to route it? To the DHCP server handing out 10.0.0.0/24 addresses on the Mikrotik router.
I’ve never setup a managed switch some point top-level points would be much appreciated.
Config of both please…
MT is a separate vendor but not difficult as netgear switches are not all that different and I have used several.
Mikrotik router - mainly standard router config on a cAP ac with private network on 192.168.88.0/24 and guest network on VLAN10 10.0.0.0/24. Slight complication of a mesh link to a repeater.
# sep/06/2023 09:25:11 by RouterOS 6.49.10
# software id = Y0E5-M1XI
# model = RBcAPGi-5acD2nD
# serial number = <edit>
add admin-mac=2C:C8:1B:7D:44:4E auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=guest-vlan vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=private \
    supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=guest \
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=croatia disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge name=private-2g security-profile=private ssid=\
    "Sea Captain's House" wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=croatia disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge name=private-5g security-profile=\
    private ssid="Sea Captain's House" wireless-protocol=802.11
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=\
    2E:C8:1B:7D:44:51 master-interface=private-2g multicast-buffering=\
    disabled name=uplink-2g security-profile=private ssid=uplink-2g \
    wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add default-forwarding=no disabled=no mac-address=2E:C8:1B:7D:44:4F \
    master-interface=private-2g name=guest-2g security-profile=guest ssid=\
    "Sea Captain's Guest" vlan-id=10 vlan-mode=use-tag wds-default-bridge=\
    bridge wps-mode=disabled
add default-forwarding=no disabled=no mac-address=2E:C8:1B:7D:44:50 \
    master-interface=private-5g name=guest-5g security-profile=guest ssid=\
add name=private-dhcp ranges=192.168.88.10-192.168.88.200
add name=guest-dhcp ranges=10.0.0.10-10.0.0.200
add address-pool=private-dhcp disabled=no interface=bridge lease-time=1h \
    name=private
add address-pool=guest-dhcp disabled=no interface=guest-vlan lease-time=1h \
    name=guest
add bridge=bridge comment=defconf interface=private-2g
add bridge=bridge comment=defconf interface=private-5g
add bridge=bridge interface=guest-2g pvid=10
add bridge=bridge interface=guest-5g pvid=10
add bridge=bridge interface=uplink-2g
    192.168.88.0
add address=10.0.0.1/24 interface=guest-vlan network=10.0.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.199 client-id=1:2c:c8:1b:7d:44:b5 mac-address=\
    2C:C8:1B:7D:44:B5 server=private
add address=192.168.88.191 client-id=1:2e:c8:1b:7d:43:f9 mac-address=\
    2E:C8:1B:7D:43:F9 server=private
add address=10.0.0.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=10.0.0.1
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1,8.8.8.8 \
    gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name="ROUTER 02"
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Access point that doesn’t allow clients to get IP address on VLAN10 but works fine on LAN. Plugged into Netgear switch. If plugged directly into router the VLAN works. Remote the use tag and also works on switch although not on guest VLAN.
# sep/06/2023 09:26:10 by RouterOS 6.49.10
# software id = C9LS-Z9NL
add name=bridge
    supplicant-identity=""
/interface wireless
    country=croatia disabled=no frequency=auto installation=indoor mode=\
    20/40/80mhz-XXXX country=croatia disabled=no frequency=auto mode=\
    ap-bridge name=private-5g security-profile=private ssid=\
add default-forwarding=no disabled=no mac-address=2E:C8:1B:7D:43:F9 \
    "Sea Captain's Guest" vlan-id=10 wds-default-bridge=bridge wps-mode=\
    disabled
add default-forwarding=no disabled=no mac-address=2E:C8:1B:7D:43:FA \
    disabled
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=private-2g
add bridge=bridge interface=private-5g
/ip dhcp-client
add disabled=no interface=bridge
/system clock
/system identity
set name="AP 02 (Ground floor)"
Netgear switch confg - factory defaults:
!Current Configuration:
!System Description "M4100-26G-POE ProSafe 24-port Gigabit L2+ Intelligent Edge PoE Managed Switch, 10.0.2.20, B1.0.1.1"
!System Software Version "10.0.2.20"
!System Up Time          "0 days 0 hrs 5 mins 56 secs"
!Additional Packages     QOS,IPv6 Management,Routing
!Current SNTP Synchronized Time: SNTP Last Attempt Status Is Not Successful
vlan database
vlan routing 1 1
exit
configure
time-range
line console
exit
line telnet
exit
line ssh
exit
interface 0/1
exit
interface 0/2
exit
interface 0/3
exit
interface 0/4
exit
interface 0/5
exit
interface 0/6
exit
interface 0/7
exit
interface 0/8
exit
interface 0/9
exit
interface 0/10
exit
interface 0/11
exit
interface 0/12
exit
interface 0/13
exit
interface 0/14
exit
interface 0/15
exit
interface 0/16
exit
interface 0/17
exit
interface 0/18
exit
interface 0/19
exit
interface 0/20
exit
interface 0/21
exit
interface 0/22
exit
interface 0/23
exit
interface 0/24
exit
interface 0/25
exit
interface 0/26
exit
interface lag 1
exit
interface lag 2
exit
interface lag 3
exit
interface lag 4
exit
interface lag 5
exit
interface lag 6
exit
interface lag 7
exit
interface lag 8
exit
interface lag 9
exit
interface lag 10
exit
interface lag 11
exit
interface lag 12
exit
interface vlan 1
routing
ip address dhcp
exit
exit
What I would do is two vlans.
Trusted (private) and GUEST.
MT ROUTER → trunk port to switch (two vlans carried)
SWITCH → Gets IP from trusted private vlan, trunk port in from router.
Trunk port to AP(two vlans carried).
MT AP → trunk port from switch
→ Gets IP from trusted(private VLAN).
→ wlans untagged for private WLANs
—> wlans untagged for guest WLANs
Changes mostly!!
MT ROUTER[/u
add admin-mac=2C:C8:1B:7D:44:4E auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface vlan
add interface=bridge name=private-vlan vlan-id=11
add address-pool=private-dhcp disabled=no interface=private-vlan lease-time=1h
name=private
name=guest
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether2 comment=“to switch”
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=uplink-2g pvid=11
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=private-2g pvid=11
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=private-5g pvid=11
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=guest-2g pvid=10
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=guest-5g pvid=10
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2 untagged=uplink-2g,private-2g,private-5g pvid=11
add bridge=bridge tagged=bridge,ether2 untagged=guest-2g,guest-5g pvid=10
add comment=defconf interface=private-vlan list=LAN
add comment=defconf interface guest-vlan list=LAN
add address=192.168.88.1/24 comment=defconf interface=private-vlan network=
192.168.88.0
/ip firewall filter-address { mostly with static leases }
add address=adminIP-1 list=Admin comment=“admin desktop”
add address=adminIP-2 list=Admin comment=“admin laptop”
add address=adminIP-3 list=Admin comment=“admin smartphone”
add address=adminIP-3 list=Admin comment=“admin remote mobile vpn like wireguard”
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=accept chain=input comment=“trusted vlan” in-interface=private-vlan src-address-list=Admin
add action=accept chain=input comment=“Allow LAN DNS queries-UDP”
dst-port=53 in-interface-list=LAN protocol=udp
add action=accept chain=input comment=“Allow LAN DNS queries - TCP”
dst-port=53 in-interface-list=LAN protocol=tcp
add action=drop chain=input comment=“drop all else”
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
/tool mac-server
set allowed-interface-list=NONE
MT AP.. CHANGES mostly.
add name=bridge vlan-filtering=yes
add bridge=bridge ingress-filtering=yes frame-types=admit-only-vlan-tagged interface=ether1
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=private-2g vlan-ids=11
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=private-5g vlan-ids=11
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=guest-2g vlan-ids=10
add bridge=bridge ingress-filtering=yes frame-types=admit-priority-and-untagged interface=guest-5g vlan-ids=10
add bridge=bridge tagged=bridge,ether1 untagged=private-2g,private-5g vlan-ids=11
add bridge=bridge tagged=bridge untagged=guest-2g,guest-5g vlan-ids=10
/ip dhcp-client
add disabled=YES interface=bridge
add name=manage
add interface=private-vlan list=manage
add interface=ether2-access list=manage
set discover-interface-list=manage
add address=192.168.88.X/24 comment=defconf interface=private-vlan network=
192.168.88.0 interface=private-vlan n network=192.168.10.0 comment=“IP of capac on trusted subnet”
add address=192.168.55.1/24 interface=ether2-access network=192.168.55.0 comment=“ether2 access off bridge”
set allow-remote-requests=yes servers=192.168.88.1
{ Note: Done so all dns requests use trusted subnet }
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.88.1 comment=“ensures route avail through trusted subnet gateway”
/tool mac-server
set allowed-interface-list=manage
On the capac, I took ether2 off the bridge, this allows you to access the router and config separate from teh bridge so far less likely to get locked out.
Its also useful as a backup to access the router in case the bridge burps at any time.
If the Capac is easily accessible easy, if not when installing it ensure you put a second cable attached to the capac and string the cable to a location where you could access it with a laptop.
One simply changes ipv4 settings to any IP within the subnet.
Thanks for this. Will digest over the next few days.
yes some new concepts for you. for instance, there is no reason for anyone on guest lan and for most people on private lan to have full access to the router, only the admin does.
but everyone does need access to typically dns services…
