i’m having a question regarding the usage of a assigned /29 subnet to be used partly with NAT and without (so to say that i can use for example one ip of the subnet directly on a VM and use the built in firewall feature and for other vms use the mikrotik firewall rules)
So far i have been using all the time the built in firewall on the CHR but as i’m in a migration process i want to use for some specific vms directly the ips without any NAT though i’m unsure how i need to do that?
I’ve been trying to setup one ip of the subnet directly on a VM with defined gateway the CHR (where the subnet is being routed on) but no success so far.
Does anyone have a hint on this?
Thanks!
