[hEX] 80 PPPoE session on RB750Gr3
Hi there,
I’m planning to put 80 PPPoE session on RB750Gr3. I’ve seen that this device has double core 880 MHz CPU.
Do you think RB750Gr3 it will be a good choiche?
It depends.
How much traffic will it there be?
What other things will the box do?
(firewall, QoS, NAT, etc.)
Hi and thanks for your answer,
Traffic will be lower than 50 Mbit in total and there is no NAT, firewall or QOS. Just PPPoE server function.
Then the hEX should be fine :slight_smile:
Thanks!
I will let you know as I will install and test it.
