Hi there,
my first post so don’t be hard on me ![]()
I’m trying to setup a trunk port on ether5 of my Hex router, afterwards I connect it to a CSS326 switch that I think I’ve managed to configure already.
The problem now is that a client get’s an IP, but gets no internet access, so I think I’m missing something, but not sure what. I’m also not sure if what I have is configured properly.
Config:
# oct/07/2020 19:19:04 by RouterOS 6.47.4
add admin-mac=B8:69:F4:C3:DC:C2 auto-mac=no comment=defconf name=bridge protocol-mode=none
/interface vlan
add interface=bridge name=vlan2 vlan-id=2
add interface=bridge name=vlan10 vlan-id=10
add interface=bridge name=vlan20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.2.70-192.168.2.100
add name=pool10 ranges=10.0.10.10-10.0.10.100
add name=pool20 ranges=10.0.20.10-10.0.20.100
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=pool10 disabled=no interface=vlan10 name=server-vlan10
add address-pool=pool20 disabled=no interface=vlan20 name=server-vlan20
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add address=192.168.2.1/24 comment=defconf interface=ether2 network=192.168.2.0
add address=192.168.1.150/24 interface=ether1 network=192.168.1.0
add address=10.0.10.1 interface=vlan10 network=10.0.10.0
add address=10.0.20.1 interface=vlan20 network=10.0.20.0
add address=192.168.2.0/24 disabled=yes interface=vlan2 network=192.168.2.0
/ip dhcp-client
add address=10.0.10.0/32 dns-server=10.0.10.1 gateway=10.0.10.1 netmask=32
add address=10.0.20.0/32 dns-server=10.0.20.1 gateway=10.0.20.1 netmask=32
add address=192.168.2.0/24 comment=defconf dns-server=192.168.2.40 gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes servers=192.168.1.254
/ip dns static
add address=192.168.2.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=8080 protocol=tcp to-addresses=192.168.2.40
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=943 protocol=tcp to-addresses=192.168.2.40
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=9443 protocol=tcp to-addresses=192.168.2.40
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=1194 protocol=udp to-addresses=192.168.2.40
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=443 protocol=tcp to-addresses=192.168.2.40
add action=dst-nat chain=dstnat dst-address=192.168.1.150 dst-port=9091 protocol=tcp to-addresses=192.168.2.40
add action=masquerade chain=srcnat out-interface=ether5 src-address=10.0.10.0/24
add distance=1 gateway=192.168.1.254
/ip ssh
set forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Vilnius
/tool mac-server
/tool mac-server mac-winbox
Thanks in advance.
