# HEX Lite for routing between subnets
**URL:** <https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206>\
**Category:** General\
**Created:** [November 20, 2024, 12:33pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206 "2024-11-20T12:33:35Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![ddrums95](https://forum.mikrotik.com/letter_avatar/ddrums95/32/6_449c533f586939b6e5f246632a46421f.png) [@ddrums95](https://forum.mikrotik.com/u/ddrums95)\
**Post date:** [November 20, 2024, 12:33pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/1 "2024-11-20T12:33:35Z")
</div>
Good day everyone,
I have an interesting problem and need some assistance to first find out if it is possible with the hardware I have and secondly to be pointed in the right direction for a solution.
I have 5 devices with the following IPs (4 devices with the same IP and one controller device) see the attached image. They are all connected to a RB750r2 (Hex Lite):
192.168.0.201 - connected to ether1
192.168.10.170 - connected to ether2
192.168.10.170 - connected to ether3
192.168.10.170 - connected to ether4
192.168.10.170 - connected to ether5
I want the device connected to ether1 (192.168.0.201) to be able to communicate with the device on ether2 (192.168.10.170). However, the kicker is that the ether1 device should see the packets coming from 192.168.0.170 and the device on ether2 from 192.168.10.201, respectively.
This should repeat for ether3,4 and 5 with the device on ether1 seeing it as devices 192.168.0.171,172,173 respectively and each device on ether3,4 and 5 seeing the communication from 192.168.10.201.
Devices on ether2,3,4, and 5 should not be able to communicate with each other (Don’t think they can as that will result in IP address conflicts).
I have tried a setup with dst-Nat and source nat, however, this did not work at all as there was no communication between the devices.
Is dst-nat, or src-nat the way to go to allow this type of setup? Is it even possible with my hardware? is there other stuff I should try?
Any help would be appreciated.
Best regards,
Darius
 ![Screenshot 2024-11-20 142548.png](https://data-discourse.cdn.mikrotik.com/original/3X/1/1/114aa065c3aaf46380d180e46c6091ff2b956723.png)
**Author:** ![rextended](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/rextended/32/67729_2.png) [@rextended](https://forum.mikrotik.com/u/rextended)\
**Post date:** [November 20, 2024, 12:49pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/2 "2024-11-20T12:49:22Z")
</div>
Since you have not written anywhere the reason why the peripherals have that ridiculous configuration,
and since it is obvious that they must not have the same address, otherwise they create problems…
The solution is simple: **use different IPs on each device** , as is right and logical that it should be…
**Author:** ![abbio90](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/abbio90/32/2852_2.png) [@abbio90](https://forum.mikrotik.com/u/abbio90)\
**Post date:** [November 20, 2024, 1:00pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/3 "2024-11-20T13:00:08Z")
</div>
I think you can insert 4VRF and remap with netmap.
**Post date:** [November 20, 2024, 2:27pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/4 "2024-11-20T14:27:15Z")
</div>
_Certo, est prus fàcile chi configurare bè is IP…_
[Sure, easier than setting up IPs correctly…]
**Post date:** [November 20, 2024, 2:55pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/5 "2024-11-20T14:55:49Z")
</div>
Yes of course, I agree with you, it’s a crazy scenario. Maybe there’s a reason why it has to have 4 same IPs. I’m very curious.
**Author:** ![jaclaz](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/jaclaz/32/55652_2.png) [@jaclaz](https://forum.mikrotik.com/u/jaclaz)\
**Post date:** [November 20, 2024, 5:25pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/6 "2024-11-20T17:25:15Z")
</div>
I think a line must be drawn somewhere, it is not the first and only case why someone might want or need to have several devices with the same IP.
Only as examples:
[http://forum.mikrotik.com/t/access-multiple-devices-with-same-ip-address/106788/1](http://forum.mikrotik.com/t/access-multiple-devices-with-same-ip-address/106788/1)
[http://forum.mikrotik.com/t/connecting-to-multiple-devices-with-same-ip-address/159052/1](http://forum.mikrotik.com/t/connecting-to-multiple-devices-with-same-ip-address/159052/1)
[http://forum.mikrotik.com/t/map-devices-with-identical-ip-to-external-ip-based-on-port/180074/1](http://forum.mikrotik.com/t/map-devices-with-identical-ip-to-external-ip-based-on-port/180074/1)
Maybe one could start with the assumption that a request for help/assistance from a new member might (even if it is a remote possibility) be not completely crazy and I am pretty sure that it is perfectly possible to ask for the context/reasons/etc. without implying that the new member is crazy, ignorant or both.
@ddrums95
Have a look at the topics linked above, they might represent (it depends if you are running Ros6 or 7) a possible solution, or at least give you some ideas to experiment with..
**Author:** ![anav](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/anav/32/2112_2.png) [@anav](https://forum.mikrotik.com/u/anav)\
**Post date:** [November 20, 2024, 7:47pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/7 "2024-11-20T19:47:32Z")
</div>
We need a more granular understanding of the relationship between the controller and devices.
A. Who initiates traffic.
 → does the controller reach out first and state any devices here
—\> do the devices reach out first, is there any controller out there.
B. How does the controller know which device its talking to since all hardware devices are given the same IP address?
Is there a specific port or perhaps mac address assigned to each device the controller is aware of, or discovers in the broadcast and answer kind off process??
**Post date:** [November 21, 2024, 5:19am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/8 "2024-11-21T05:19:37Z")
</div>
I do agree that the setup is crazy and something that is not the norm at all.
The reason for the 4 devices connected to ether2,3,4 and 5 is that one set of firmware is loaded on the devices, hence one hardcoded IP address. Unfortunately, the conditions where these devices are used, make it extremely difficult to keep track of which device is where in the system physically and you could end up having multiple of the same IP devices connected by accident not to mention the fact that the reprogramming of the devices is not an easy task for the type of installation.
It is therefore decided to at least try this solution (hence my asking if it is possible) where you do not have to worry about the IP programmed on the device and that some other device ( hopefully the RB750r2) can handle the separation.
The “controller” will communicate primarily via UDP to the devices and they will reply. However, there will be occasional TCP connections as well from the controller or other devices connected to the ether1 port (via other unmanaged switches).
The controller expects devices on IP 170, 171, 172 and 173, that is the reason why those IPs are assigned. The idea is that the operator will plug the first field device into ether2 port as that is dedicated to the first device which translates (eventually) to 192.168.0.170. Device 2 will connect to its dedicated port ether3 which will eventually translate to 192.168.0.171 as seen by the controller.
I hope this gives a bit clearer context of why these assignments are made. And I do appreciate your comments and help thus far.
@jaclaz, thank you I will view those topics and see if I can find something. Thanks @abbio90, will look into 4VRF.
I appreciate everyone’s time and ideas.
Best regards,
Darius
**Post date:** [November 21, 2024, 7:40am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/9 "2024-11-21T07:40:11Z")
</div>
I have tried the following (with only two devices) and it does not work. The controller that tries to talk to 192.168.0.170 reaches the interface (on the router) through ping, but the udp packets from the software running on it do not reach the device on ether2. and there is no reply from the device back to the controller.
```plaintext
add address=192.168.0.170/24 interface=ether1 network=192.168.0.0
add address=192.168.0.171/24 interface=ether1 network=192.168.0.0
add address=192.168.10.1 interface=ether2 network=192.168.10.1
add address=192.168.10.1 interface=ether3 network=192.168.10.1
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address=192.168.0.170 new-connection-mark=port1
add action=mark-connection chain=prerouting dst-address=192.168.0.171 new-connection-mark=port2
add action=mark-routing chain=prerouting connection-mark=port1 new-routing-mark=port1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=port2 new-routing-mark=port2 passthrough=no
add action=dst-nat chain=dstnat dst-address=192.168.0.170 dst-port=80 protocol=tcp to-addresses=192.168.10.2
add action=dst-nat chain=dstnat dst-address=192.168.0.171 dst-port=80 protocol=tcp to-addresses=192.168.10.2
add action=masquerade chain=srcnat out-interface=ether2
add action=masquerade chain=srcnat out-interface=ether3
add distance=1 dst-address=192.168.10.0/24 gateway=ether2 routing-mark=port1
add distance=1 dst-address=192.168.10.0/24 gateway=ether3 routing-mark=port2
**Post date:** [November 21, 2024, 9:37am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/10 "2024-11-21T09:37:54Z")
</div>
Without considering the various problems of ARP and IPs being the same on different ports, where they not only have to pass through, but also do NAT,
the simplest solution is to buy 4 least expensive router ever and do all local NAT.
When you use NAT or Routing, you are already at Leve 3,
but at Level 2 192.168.10.170 cause confusion on ARP table, and the position of expected 192.168.10.170 change continuosly…
**Post date:** [November 21, 2024, 10:29am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/11 "2024-11-21T10:29:36Z")
</div>
So you are on 6.x (routing-mark in /ip route).
Sob’s suggestion here:
uses netmap, not dst-nat.
That may (or may not) make a difference.
**Post date:** [November 21, 2024, 10:31am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/12 "2024-11-21T10:31:56Z")
</div>
Thank you @rextended. If I am able to somehow set them up as dynamic IPs and get their IP from the router, will that make things easier?
I will still have to have device 1 on ether 2 which ultimately translates to the static IP 192.168.0.170 at the controller side, and 171, 172,173 for devices on ether3,4,5 respectively.
**Post date:** [November 21, 2024, 10:33am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/13 "2024-11-21T10:33:06Z")
</div>
> [Connecting to multiple devices with same IP-address](http://forum.mikrotik.com/t/connecting-to-multiple-devices-with-same-ip-address/159052/1)
Yes, I downgraded to be able to do the routing mark. Let me try the netmap 🙂
Thanks for your time! Do appreciate it
**Post date:** [November 21, 2024, 10:40am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/14 "2024-11-21T10:40:03Z")
</div>
Unfortunately, I get the same results as with dst-nat. As with dst-nat, I can see the connection coming from the controller, it just doesn’t get routed through and out by ether2/3.
 ![Screenshot 2024-11-21 123801.png](https://data-discourse.cdn.mikrotik.com/original/3X/7/4/747a3370e9bbfeefeb8233b0d97c3d35b612147e.png)
**Post date:** [November 21, 2024, 10:47am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/15 "2024-11-21T10:47:14Z")
</div>
I would define “rare” the case that something Sob suggests is not working.
Post your full configuration, maybe there is _something else_ that needs to be corrected or some “wrong” other setting that some of forum members may be able to spot..
Netmap (from what I understand) should be “protocol agnostic” (i.e. TCP or UDP should be treated the same).
**Post date:** [November 21, 2024, 11:59am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/16 "2024-11-21T11:59:33Z")
</div>
I would agree with you 100% that I am not doing something correct. These experts on this forum are experts for a reason!
Here is my full config exported after the Sob example you led me to:
```plaintext
# jan/02/1970 04:33:43 by RouterOS 6.49.13
# software id = B8UP-SUY0
# model = RB750r2
# serial number = HG409GRBSM2
set [find default=yes] supplicant-identity=MikroTik
/ip hotspot profile
set [find default=yes] html-directory=hotspot
/ip firewall mangle
add action=dst-nat chain=netmap dst-address=192.168.0.170 to-addresses=192.168.10.2
add action=dst-nat chain=netmap dst-address=192.168.0.171 to-addresses=192.168.10.2
**Post date:** [November 21, 2024, 1:03pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/17 "2024-11-21T13:03:08Z")
</div>
there must be a typo/inversion in the referenced post 😮 chain is dstnat action is netmap.
your:
```plaintext
should be:
```plaintext
add action=netmap chain=dstnat dst-address=192.168.0.170 to-addresses=192.168.10.2
add action=netmap chain=dstnat dst-address=192.168.0.171 to-addresses=192.168.10.2
**Post date:** [November 22, 2024, 6:57am UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/18 "2024-11-22T06:57:59Z")
</div>
> your:
> ```plaintext
> /ip firewall nat
> should be:
> ```plaintext
> /ip firewall nat
Well, it did do something by inverting the chain and action. I now at least get a packet on the ether2 interface. Unfortunately, there is no other communication.
Any other idea what I can try?
All the best,
Darius
 ![Screenshot 2024-11-22 085652.png](https://data-discourse.cdn.mikrotik.com/original/3X/8/6/86ee27d99eea9cf6f5499c8675105e2fac088cd4.png)
**Post date:** [November 22, 2024, 2:36pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/19 "2024-11-22T14:36:48Z")
</div>
I don’t know, as said I believe (but I may well be wrong) that netmap maps “everything”, but maybe there is the need to specify protocols and/or ports. 😕
But then it could be that for _some reasons_ your tool/program/whatever does not expect this kind of netmapping from/to IP addresses.
I am not sure how exactly it will work, if this is the case, using (in v7) the vrf approach, essentially the approach is the same, from what I understand, using vrf should be only the v7 version of routing-marks, but maybe there is some slight difference that makes it work, cannot say.
**Post date:** [November 23, 2024, 2:10pm UTC](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206/20 "2024-11-23T14:10:42Z")
</div>
Ok, I did a few tests in GNS3, and the vrf approach seems to be working (at least I can ping both with ICMP and UDP from PC to the two targets).
Setup:
VPCS named PC-source set with ip 192.168.0.254/24 connected to ether1 of a Mikrotik CHR (runnning 7.15.3)
VPCS named target1 set with ip 192.168.10.2/24 connected to ether2 of the CHR
VPCS named target2 set with ip 192.168.10.2/24 connected to ether3 of the CHR
To ping target1, ping 192.168.0.170
To ping target2, ping 192.168.0.171
The CHR configuration:
```plaintext
/ip vrf
add interfaces=ether2 name=vrf2
add interfaces=ether3 name=vrf3
add address=192.168.10.1/32 interface=ether2 network=192.168.10.1
add address=192.168.10.1/32 interface=ether3 network=192.168.10.1
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address=192.168.0.170 new-connection-mark=port2
add action=mark-connection chain=prerouting dst-address=192.168.0.171 new-connection-mark=port3
add action=mark-routing chain=prerouting connection-mark=port2 new-routing-mark=vrf2 passthrough=no
add action=mark-routing chain=prerouting connection-mark=port3 new-routing-mark=vrf3 passthrough=no
add dst-address=192.168.10.2/32 gateway=ether2@vrf2 routing-table=vrf2
add dst-address=192.168.10.2/32 gateway=ether3@vrf3 routing-table=vrf3
add dst-address=192.168.0.0/24 gateway=ether1 routing-table=vrf2
add dst-address=192.168.0.0/24 gateway=ether1 routing-table=vrf3
But - in the same setup - this configuration (without VRF) works as well:
```plaintext
/routing table
add fib name=table2
add fib name=table3
/ip firewall mangle
add action=mark-routing chain=prerouting connection-mark=port2 new-routing-mark=table2 passthrough=no
add action=mark-routing chain=prerouting connection-mark=port3 new-routing-mark=table3 passthrough=no
add dst-address=192.168.10.2/32 gateway=ether2 routing-table=table2
add dst-address=192.168.10.2/32 gateway=ether3 routing-table=table3
[Next page](https://forum.mikrotik.com/t/hex-lite-for-routing-between-subnets/180206.md?page=2)
