hEX lite, function of ports
Hello.
I see what hEX lite router have WAN and LAN labels on case.
Is it true or any port equal and they can have any functions ? Exclude PoE of course.
Regards, Sergey.
All ports are totally equal and can be anything.
The labels are just how the router behaves with default (factory) config.
You can reconfigure the router to do anything.
Thanks.
I would like to see all ports to be able to run netinstall - otherwise they are not totally equal.
