Our OSPF session will not connect. When doing a wireshark capture I see the correct auth from the cisco . However, the Microtik Hex lite router shows auth type unknown and auth unknown.
Here are the OSPF setting in the Microtik
/routing ospf instance set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 !mpls-te-area !mpls-te-router-id nam
e=default out-filter=ospf-out redistribute-bgp=no redistribute-connected=as-type-1 redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=66.44.199.3 !routing-table !use-dn
/routing ospf area set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/routing ospf area add area-id=0.0.0.1 default-cost=1 disabled=no inject-summary-lsas=no instance=default name=area1 type=stub
/routing ospf interface add authentication=md5 authentication-key=XXXXXX authentication-key-id=1 cost=10 dead-interval=40s disabled=no hello-interval=10s instance-id=1 interface=ether1 network-type=default passive=no priority=1 retransmit-interval=5s transmit-delay=1
s use-bfd=no
