hello ,
i ask for some advice / help.
i have a hex poe lite with the problem that it’s not passing over 50-60mbit of traffic between lan ports that are in bridge.
the hex poe is “sitting” between 2 ptp links and is bridging together those links, PLUS it’s routing internet for the person that is using it on that location.
ptp links are capable of passing 100+mbits of traffic at the same time by themselves. they were doing it for years while there was a stupid switch between them, now i just threw away the stupid switch and installed a hex poe lite device so i have power control and i can separate networks.
test ptp1<->HEX goes 100mbit
test ptp2<->HEX goes 100mbit
test ptp1->ptp2 goes 50mbit
test ptp1<-ptp2 goes 100mbit
bypassing the hex ptp1<->ptp2 goes 100mbits.
i have 2 bridges, bridge1 is my network, bridge2 is network to be used on location (bridge2 is routed).
eth1 and eth5 are in bridge2 , eth2,3,4 are my devices and are in bridge1.
i have problem of speed inside bridge1.
config:
set [ find default-name=ether1 ] name=ether1-TPLinkGORE
set [ find default-name=ether2 ] name=ether2-LHG
set [ find default-name=ether3 ] name=ether3-Powerbeam poe-out=forced-on
set [ find default-name=ether4 ] name=ether4-NBE13AC poe-out=off
add name=bridge1
add name=bridge2-sandi
add name=dhcp_pool0 ranges=192.168.30.20-192.168.30.254
add address-pool=dhcp_pool0 disabled=no interface=bridge2-sandi lease-time=1w \
name=dhcp1
/queue simple
add burst-time=15s/15s max-limit=15M/50M name=queue1-sandi target=\
bridge2-sandi
add bridge=bridge1 interface=ether2-LHG
add bridge=bridge1 interface=ether3-Powerbeam
add bridge=bridge1 interface=ether4-NBE13AC
add bridge=bridge2-sandi interface=ether1-TPLinkGORE
add bridge=bridge2-sandi interface=ether5
add address=192.168.2.13/24 interface=bridge1 network=192.168.2.0
add address=192.168.30.1/24 interface=bridge2-sandi network=192.168.30.0
add address=192.168.30.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.30.1
set servers=1.1.1.1,8.8.8.8
add action=fasttrack-connection chain=forward connection-state=\
established,related disabled=yes
add action=accept chain=forward connection-state=established,related \
disabled=yes
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=192.168.2.1
/ip service
set www disabled=yes
/routing bfd interface
/system identity
set name="Sandi POE"
this is fairly simple config.
i can only think that the problem is - that i did NOT reset the hex prior to mounting, it’s running the default out-of-the-box config and ros version is 6.48.6
