hEX Poe IPv6 ULA not pingable
Hi all,
First post here so be gentle :wink:
Running on a hEX PoE
# mar/10/2022 20:40:26 by RouterOS 7.1
# software id = MGZY-P571
# model = RB960PGS
/ipv6 address
add address=fd87:cc61:ad56:28::ff interface=bridge.28
/ipv6 nd
set [ find default=yes ] advertise-dns=no disabled=yes
add advertise-dns=no interface=bridge.28
This gives me a nice https://en.wikipedia.org/wiki/Unique_local_addres on both a windows pc as well on a debian pc.fd87:cc61:ad56:28::ff is NOT pingable. As soon as i change the address on brige.28 to something outside fc00::/7 it IS pingable.
You would suspect some input firewall rule blocking this but the IPv6 firewall is compleet stock and I find no reference to anything fc00::/7
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-established,related,untracked
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-polic
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interf
To make things more interesting; there is no doubt the MikroTik is recieving the icmp6 echo request:
\[admin@mikrotik\] /ipv6/firewall/connection> print where PROTOCOL=ICMPv6
Columns: PROTOCOL, SRC-ADDRESS, DST-ADDRESS, TIMEOUT
# PROTOCOL  SRC-ADDRESS                            DST-ADDRESS            TIMEOUT
3 icmpv6    fd87:cc61:ad56:28:701b:575f:9665:e46d  fd87:cc61:ad56:28::ff  29s
So question, why does MikroTik threat ULA any other than Global Routable Addresses?
Found it. Lesson learned: look outside of /ipv6/ :confused:
\[admin@mikrotik\] > /routing/rule/export
# mar/29/2022 21:10:49 by RouterOS 7.1.5
# model = RB960PGS
add action=drop comment=multicast disabled=no dst-address=224.0.0.0/4
add action=unreachable comment=ULA disabled=no dst-address=fc00::/7
