hEX PoE or Netmetal ac2 powering bug
Hi,all!
I have a problem connecting Netmetal ac2 via hEX PoE powering by PoE. hEX PoE powered by 48V adapter. Only “forced on” PoE out on the hEX PoE turns on Netmetal ac2 router.
RoS 6.47 or 6.46.6.
There is no problem connecting Netmetal ac2 via CRS328-24P.
Is this a bug or feature?
Try to power up using 24v original power supply.
Regards.
Bad idea. I need standart 48V 802.3 PoE for cameras.
Is it software or hardware bug?
First disconnect a bit your cameras and power up your AP alone. If fails with 48v, try with 24v.
Most probably if all works OK, you are overloading with your cameras your hEX PoE.
Regards.
This means hEX PoE normally works only with the 24V adapter? So this is hardware bug?
It should works using 48v power supply, but alone (without your cameras).
Regards.
As far as I understand, this is hardware problem and it’s not worth waiting for the problem to be fixed in ROS7. Dear Mikrotik’s, is that correct?
