Hello everyone!
I have the following hEX POE router:
WebFig v6.37.3 (stable)
Architecture Name mipsbe
Board Name hEX PoE
Version 6.37.3 (stable)
Build Time Nov/28/2016 11:11:46
Factory Software 6.36
Routerboard
Model 960PGS
Firmware Type qca9550L
Factory Firmware 3.41
Current Firmware 3.41
Upgrade Firmware 3.34
Router voltage: 48V
I am trying to connect a Texas Instruments PD board to it: http://www.ti.com/lit/ug/slvu108/slvu108.pdf
This is using the 802.3af standard
My problem is that the Auto On feature is not working, it says the router is waiting for load, the load on the poe is approximately 1W
Detection resistor is: 24,9k ohm which should be in range of the routers required detection resistor.
After some time, the Auto On is turning on the system then it is working fine, this time is pretty random from 20 seconds to several minutes, some times it does not turn it on at all.
The circuit is tested and works with this switch: https://www.amazon.com/DAHUA-4-Port-PoE-Switch-DH-PFS3106-4P-60/dp/B01M10NX1C
The Force On is working also the other networking features are working as they should.
Is there any way to make this circuit compatible with the hEX POE router?
Thanks & Regards,
Gergely Nagy
