hEX PoE - powering IP cameras and other Mikrotik device at same time ?
Greetings !
I’m using hEX PoE to power couple of Hikvision IP cameras. They don’t want to work on 24v power supply but they do work when I hook on 48v power adapter. But, when I try to power QRT2 at the same time, it won’t work (obviously, since QRT2 is passive PoE and shows short circuit because of high voltage).
Is there a way to pair both QRT2 and IP camers on hEX PoE at the same time ?
Thanks !
This is possible only by using a POE injector with an additional power source with the required power for an IP camera.
