I’m facing issues trying to get 1G rate when connected directly to laptop or PC or even wifi ap. i have searched the forum and it seems some of them have similar behavior like this http://forum.mikrotik.com/t/rb750gr3-report-and-questions/102735/1 yet i’m not able to figure it out.
i would appreciate any hint to identify if it is something with my config or a limitation in this hardware version and can be solved by purchasing the newer version like the newer hEX / E50UG
[admin@MikroTik] > /export compact
# 2024-12-23 18:32:10 by RouterOS 7.17rc3
# software id = xxxx-xxxx
# model = RB750Gr3
# serial number = xxxxxxxxxxx
add admin-mac=08:55:31:34:B4:7F auto-mac=no comment=defconf name=bridge port-cost-mode=short
set [ find default-name=ether1 ] comment=Uplink
set [ find default-name=ether2 ] comment="WiFi 1st DLINK" disabled=yes
set [ find default-name=ether3 ] comment="WiFi Router"
set [ find default-name=ether4 ] comment="WiFi6 2nd"
set [ find default-name=ether5 ] advertise=100M-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,1G-baseX comment="My PC"
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=ibraali
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 path-cost=10 trusted=yes
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 path-cost=10 trusted=yes
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
/interface ovpn-server server
add mac-address=FE:5C:A4:18:5D:8B name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=185.228.168.125,185.228.169.125
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Asia/Dubai
/system note
set show-at-login=no
/system package update
set channel=development
/system scheduler
add interval=1d name=dlink on-event="/interface enable [find name=\"ether2\"]\r\
\ndelay 7200;\r\
\n/interface disable [find name=\"ether2\"]" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2023-06-18 start-time=\
20:00:00
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=no down-script="ping test failed" host=8.8.8.8 http-codes="" interval=3s test-script="" type=icmp up-script="ping test working"
