hEX / ROS 7.13.5: IPv6 Routing issue - inter-network and LAN/WAN routing not working
Hi everyone,
Got a situation where I can ping / communicate while inside a network, but there’s a bug in my routing that denies any communication inter-LAN/WAN.
Being fairly new to ROS, I’m a bit lost on why.
  1. Firewall:
  • has top AllowAll rules for all interfaces and directions for debugging
  • ICMPv6, v6-Delegation and ICMP are explicitly allowed
  1. IPv4:
  • has no internet access (running IPv6 only at the moment)
  • two networks (bridge1 LAN and eth5 MGMT)
    → addresses bound to the interfaces, with DHCPs running
  1. IPv6
  • two GUA networks (bridge1 LAN and eth5 MGMT)
    → addressing via DHCPv6 PD from WAN, distribution via router advertisement
  • two ULA networks (bridge1 LAN and eth5 MGMT)
    → set to the interfaces as IPv6 addresses and advertised.
  1. WAN
  • PPPoE on VLAN7 on eth1
IPv6 route looks like this
[Flags: D - DYNAMIC; A - ACTIVE; c - CONNECT, d - DHCP, v - VPN; + - ECMP
Columns: DST-ADDRESS, GATEWAY, DISTANCE
     DST-ADDRESS               GATEWAY                                 DISTANCE
DAd+ ::/0                      fe80::bac2:53ff:fe34:73%pppoe-out1_DGN         1
DAv+ ::/0                      pppoe-out1_DGN                                 1
DAd  2a01:41e3:5001:ae00::/56                                                 1
DAc  2a01:41e3:5001:ae00::/64  bridge1                                        0
DAc  2a01:41e3:5001:ae01::/64  ether5_mgmt                                    0
DAc  fd21:6584:3b21:1216::/64  ether5_mgmt                                    0
DAc  fd21:6584:3b21:1314::/64  bridge1                                        0
DAc  fe80::%ether1_wan/64      ether1_wan                                     0
DAc  fe80::%ether5_mgmt/64     ether5_mgmt                                    0
DAc  fe80::%bridge1/64         bridge1                                        0
DAc  fe80::%pppoe-out1_DGN/64  pppoe-out1_DGN                                 0
DAc  fe80::%007_DGN/64         007_DGN                                        0
But the system behaves as if no routes were defined…
Additional Info:
/ipv6/settings> print
                  disable-ipv6: no
                       forward: yes
              accept-redirects: yes-if-forwarding-disabled
  accept-router-advertisements: yes-if-forwarding-disabled
          max-neighbor-entries: 4096
Interfaces
Flags: D - dynamic; X - disabled, R - running; S - slave; P - passthrough
 0  R   name="ether1_wan" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500
        l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:57:EB:2D ifname="eth0" ifindex=7 id=1
        last-link-up-time=2024-09-22 11:19:10 link-downs=0
 1  RS  name="ether2" default-name="ether2" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596
        max-l2mtu=2026 mac-address=DC:2C:6E:57:EB:2E ifname="eth1" ifindex=8 id=2
 2   S  name="ether3" default-name="ether3" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596
        max-l2mtu=2026 mac-address=DC:2C:6E:57:EB:2F ifname="eth2" ifindex=9 id=3
        link-downs=0
 3   S  name="ether4" default-name="ether4" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1596
        max-l2mtu=2026 mac-address=DC:2C:6E:57:EB:30 ifname="eth3" ifindex=10 id=4
        link-downs=0
 4  R   name="ether5_mgmt" default-name="ether5" type="ether" mtu=1500 actual-mtu=1500
        l2mtu=1596 max-l2mtu=2026 mac-address=DC:2C:6E:57:EB:31 ifname="eth4" ifindex=11 id=5
 5  R   name="007_DGN" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1592
        mac-address=DC:2C:6E:57:EB:2D ifname="vlan11" ifindex=13 id=11
 6  R   name="bridge1" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1596
        mac-address=DC:2C:6E:57:EB:2E ifname="br0" ifindex=12 id=6
        last-link-up-time=2024-09-22 11:18:59 link-downs=0
 7  R   name="pppoe-out1_DGN" type="pppoe-out" mtu=1492 actual-mtu=1492 ifname="ppp0"
        ifindex=14 id=7 last-link-down-time=2024-09-22 11:19:12
        last-link-up-time=2024-09-22 11:19:12 link-downs=1
DHCPv6 Client
Flags: D - dynamic; X - disabled, I - invalid
 0    interface=pppoe-out1_DGN status=bound duid="0x00030001dc2c6e57eb2d"
      dhcp-server-v6=fe80::bac2:53ff:fe34:73 request=prefix add-default-route=yes
      default-route-distance=1 use-peer-dns=yes dhcp-options=OPTION_ORO
      pool-name="pool-pppoe-pd" pool-prefix-length=64 prefix-hint=::/0
      dhcp-options=OPTION_ORO prefix=2a01:41e3:5001:ae00::/56, 22h19m55s
IPv6 Pools
/ipv6/pool> print detail
Flags: D - dynamic
 0 D id=5 name="pool-pppoe-pd" prefix=2a01:41e3:5001:ae00::/56 prefix-length=64
     expires-after=22h20m53s
ND settings
/ipv6/nd> print
Flags: X - disabled, I - invalid; * - default
 0  * interface=bridge1 ra-interval=3m20s-10m ra-delay=3s mtu=unspecified
      reachable-time=unspecified retransmit-interval=unspecified ra-lifetime=30m
      ra-preference=medium hop-limit=unspecified advertise-mac-address=yes advertise-dns=yes
      managed-address-configuration=no other-configuration=no dns="" pref64=""
 1    interface=ether5_mgmt ra-interval=3m20s-10m ra-delay=3s mtu=unspecified
and Prefixes
Flags: X - disabled, I - invalid; D - dynamic
 0  D prefix=fd21:6584:3b21:1314::/64 6to4-interface=none interface=bridge1 on-link=yes
      autonomous=yes valid-lifetime=4w2d preferred-lifetime=1w
 1  D prefix=fd21:6584:3b21:1216::/64 6to4-interface=none interface=ether5_mgmt on-link=yes
 2  D prefix=2a01:41e3:2561:b00::/64 6to4-interface=none interface=bridge1 on-link=yes
 3  D prefix=2a01:41e3:2561:b01::/64 6to4-interface=none interface=ether5_mgmt on-link=yes
and Addresses
Flags: X - disabled, I - invalid, D - dynamic; G - global, L - link-local
 0  G address=2a01:41e3:2561:b00:de2c:6eff:fe57:eb2e/64 from-pool=pool-pppoe-pd
      interface=bridge1 actual-interface=bridge1 eui-64=yes advertise=yes no-dad=no
 1  G address=2a01:41e3:2561:b01:de2c:6eff:fe57:eb31/64 from-pool=pool-pppoe-pd
      interface=ether5_mgmt actual-interface=ether5_mgmt eui-64=yes advertise=yes no-dad=no
 2  G address=fd21:6584:3b21:1216:de2c:6eff:fe57:eb31/64 from-pool="" interface=ether5_mgmt
 3  G address=fd21:6584:3b21:1314:de2c:6eff:fe57:eb2e/64 from-pool="" interface=bridge1
 4 DL address=fe80::de2c:6eff:fe57:eb2e/64 from-pool="" interface=bridge1
      actual-interface=bridge1 eui-64=no advertise=no no-dad=no
 5 DL address=fe80::de2c:6eff:fe57:eb31/64 from-pool="" interface=ether5_mgmt
      actual-interface=ether5_mgmt eui-64=no advertise=no no-dad=no
 6 DL address=fe80::de2c:6eff:fe57:eb2d/64 from-pool="" interface=ether1_wan
      actual-interface=ether1_wan eui-64=no advertise=no no-dad=no
 7 DL address=fe80::de2c:6eff:fe57:eb2d/64 from-pool="" interface=007_DGN
      actual-interface=007_DGN eui-64=no advertise=no no-dad=no
 8 DL address=fe80::60f4:f35a:0:7/64 from-pool="" interface=pppoe-out1_DGN
      actual-interface=pppoe-out1_DGN eui-64=no advertise=no no-dad=no
ah, and DNS seems to work, as a try to reach a website via FQDN leads to “UDP connect: no route to host” and not "can’t be resolved.
Using two dynamic IPv6 DNS assigned by the ISP.
another thing that appears odd:
both local and remote interfaces of the PPPoE connection show as fe80:: link-locals.
to my understanding, this will not work for routed “offsite” communication…
Providing the print output from a random set of sections isn’t particularly helpful, post the output of /export in a code block (the icon above the message box when composing a message) after redacting serial number and any other identifying information.
The usual errors with setting up IPv6 is not setting add-default-route=no to the DHCPv6 client, and not setting accept-router-advertisements=yes (although with a PPPoE WAN connection this is likely unnecessary).
Unfortunately there are many different ways ISPs provide IPv6, does yours provide any information as to how their implementation operates?
Thanks tdw, info as requested follows.
→ had this set, has been corrected.
2.
→ set to “yes-if-forwarding-disabled” and “forward=yes”, so could be an issue.
/Export
# 2024-09-22 18:54:29 by RouterOS 7.13.5
# software id = YS0Q-E2S9
# model = RB750Gr3
# serial number = CC##########
add admin-mac=DC:2C:6E:57:EB:2E auto-mac=no igmp-snooping=yes name=bridge1
set [ find default-name=ether1 ] name=ether1_wan
set [ find default-name=ether5 ] name=ether5_mgmt
/interface vlan
add interface=ether1_wan name=007_DGN vlan-id=7
/interface pppoe-client
add add-default-route=yes allow=pap,chap,mschap2 disabled=no interface=007_DGN max-mru=1492 \
    max-mtu=1492 name=pppoe-out1_DGN use-peer-dns=yes user=########@dgn.digital
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-client option
add code=55 name=req_6rd value=0x010306d4
add code=6 name=req_dns_aftr value=0x00170040
/ip hotspot profile
add name=mgmt_dhcp_pool1 ranges=192.168.88.101-192.168.88.200
add name=bridge1_pool1 ranges=172.21.201.101-172.21.201.200
/ipv6 dhcp-client option
add code=64 name=OPTION_ORO value=0x0040
/port
set 0 name=serial0
add bridge=bridge1 interface=ether2 pvid=201
add bridge=bridge1 interface=ether3 pvid=201
add bridge=bridge1 interface=ether4 pvid=201
add interface=ether5_mgmt list=LAN
add interface=pppoe-out1_DGN list=WAN
add interface=ether4 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add address=192.168.88.1/24 interface=ether5_mgmt network=192.168.88.0
add address=172.21.201.1/24 interface=bridge1 network=172.21.201.0
add address-pool=mgmt_dhcp_pool1 interface=ether5_mgmt lease-time=10m name=mgmt_dhcpv4 \
    parent-queue=*FFFFFFFF
add address-pool=bridge1_pool1 interface=bridge1 name=bridge1_dhcpv4 parent-queue=*FFFFFFFF
add address=172.21.201.0/24 dns-server=172.21.201.1 gateway=172.21.201.1 netmask=24
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers="8.8.8.8,1.1.1.1,9.9.9.9,2001:4860:4860::8888,2001:4860:\
    4860::4444,2606:4700:4700::1111,2606:4700:4700::1001,2620:0:ccc::2,2620:0:ccd::2"
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" \
add action=accept chain=input comment="accept ICMP from WAN" in-interface=pppoe-out1_DGN \
    protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" \
    dst-address=127.0.0.1
add action=accept chain=input comment="allow WinBox from WAN" in-interface=pppoe-out1_DGN \
    port=8291 protocol=tcp
add action=accept chain=input comment="allow SSH from WAN" in-interface=pppoe-out1_DGN port=\
    22 protocol=tcp
add action=drop chain=input comment="drop anything else from WAN" in-interface=pppoe-out1_DGN
    in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=\
    in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=\
    out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" \
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none \
    out-interface-list=WAN
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 address
add address=::xxxx:xxxx:xxxx:xxzz eui-64=yes from-pool=pool-pppoe-pd interface=bridge1
add address=::xxxx:xxxx:xxxx:yyzz eui-64=yes from-pool=pool-pppoe-pd interface=ether5_mgmt
add address=fdxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx eui-64=yes interface=ether5_mgmt
add address=fdxx:xxxx:xxxx:xxyy:xxxx:xxxx:xxxx:xxxx eui-64=yes interface=bridge1
/ipv6 dhcp-client
add dhcp-options=OPTION_ORO dhcp-options=OPTION_ORO interface=pppoe-out1_DGN pool-name=\
    pool-pppoe-pd request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="DEBUG ONLY - IN AllowAll" in-interface-list=all
add action=accept chain=forward comment="DEBUG ONLY - FWD AllowAll" in-interface-list=all \
    out-interface-list=all
add action=accept chain=output comment="DEBUG ONLY - OUT AllowAll" out-interface-list=all
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 \
    protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." \
    dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" \
    ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" \
add action=accept chain=forward comment="defconf: accept established,related,untracked" \
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
    src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
    dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 \
    protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" \
add action=accept chain=forward comment="accept UDP traceroute" dst-port=33434-33534 port="" \
    protocol=udp src-port=""
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" \
/ipv6 firewall raw
add action=accept chain=prerouting comment="DEBUG ONLY - AcceptAll"
/ipv6 nd
set [ find default=yes ] interface=bridge1
/routing rule
add action=lookup disabled=no interface=bridge1 table=main
add action=lookup disabled=no interface=ether5_mgmt table=main
/system clock
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=ptbtime1.ptb.de
add address=ptbtime2.ptb.de
add address=ptbtime3.ptb.de
add address=ptbtime4.ptb.de
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
…many different ways ISPs provide IPv6, does yours provide any information…
The ISP is not very open in his communication, they try force you to use Fritz!Boxes provided by them.
The whole connection is DS-lite with a primary IPv6 connection via PPPoE and DHCP-PD. The DCHPv6 then provides AFTR-FQDN via an Option field. Which Option they use is not documented either.
So, my first aim was to get the whole IPv6 side up and running, and later trying to figure out the scripts for the Option… or booking a DualStack.
Issue solved. IPv6 routing now works after setting add-default-route=no on the DHCPv6 client that’s attached to the WAN-side PPPoE-interface.
Thanks again to tdw
And side note that this “how to” leads to the bug, just in case someone else uses it as reference:
https://administrator.de/tutorial/ipv6-mittels-prefix-delegation-bei-pppoe-mikrotik-632633.html
That guy is setting add-default-route=yes on both PPPoE and DHCPv6 client.
I was just about to post suggesting setting add-default-route=no to the DHCPv6 client so the PPPoE default route is used.
What are the /routing rule entries for?
I’ve made posts previously regarding DS-Lite setup. These used AFTR provided by DNS, they would need some modification to use the DHCPv6 option.
The routing rules are redundant, I think. They were added while searching for the cause of the missing routing info.
Had a chat with my ISP 2nd level support today. He’s forwarded my questions regarding the AFTR and how it’s provided to the 3rd level. Waiting for reply…
But all info I could gather on my ISP (Deutsche Giganetz) points towards an FQDN being sent either on request or per standard by the DHCPv6 somewhere within the options.
here’s the response:
They’re using DNS resolution as in RFC6334.
https://www.rfc-editor.org/rfc/rfc6334.html
Issue’s been brought up here:
http://forum.mikrotik.com/t/ds-lite-rfc-6333-rfc-6334/124743/1
and here:
http://forum.mikrotik.com/t/dslite-tunnel-is-not-working-fails-rfc6333-and-rfc2473/151902/1
Also see http://forum.mikrotik.com/t/ipv6-ds-lite/156507/1
Mhm. I’ll follow that up… seems like I’ll need to learn scripting a bit :slight_smile:
Maybe I’m lucky and my ISPs AFTR does stay constant like in the post you linked…
