hEX S does not respond on MGMT interface
So i have been working on getting my four devices to create a vlan fabric and eventually I will get a fifth device for the lab downstairs.
I can get the HAP ac2 to work because of the hardware offloading. But with the HEX S, I can see that the MGMT interface is receiving but not transmitting.
add name=bridge1 protocol-mode=none vlan-filtering=yes
/interface vlan
add interface=bridge1 name=MGMT vlan-id=1
set 0 vlan-mode=secure
set 1 vlan-mode=secure
set 2 vlan-mode=secure
set 3 vlan-mode=secure
set 4 vlan-mode=secure
set 5 vlan-mode=secure
/ip hotspot profile
add bridge=bridge1 hw=no interface=ether1
add bridge=bridge1 hw=no interface=ether2
add bridge=bridge1 hw=no interface=ether3
add bridge=bridge1 hw=no interface=ether4
add bridge=bridge1 hw=no interface=ether5
add bridge=bridge1 interface=MGMT
/interface bridge vlan
add bridge=bridge1 tagged=ether1,bridge1,MGMT vlan-ids=1
add bridge=bridge1 tagged=ether1 vlan-ids=100
add bridge=bridge1 tagged=ether1 vlan-ids=101
add bridge=bridge1 tagged=ether1 vlan-ids=200
add independent-learning=yes ports=ether1 switch=switch1 vlan-id=100
add independent-learning=yes ports=ether1 switch=switch1 vlan-id=101
add independent-learning=yes ports=ether1 switch=switch1 vlan-id=200
add independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=1
add address=192.168.0.5 interface=MGMT network=192.168.0.0
add address=192.168.0.0/24
Not sure what i am doing wrong.
hEX S doesn’t support vlan filtering on switch chip.
Only on the bridge.
Please use this reference as a guide (HINT: also get rid of vlan1 as your management vlan, use 101 or something else)
Yes, i do plan on using somethings else for the management VLAN but as right now, changing that would cause a lot more disruption than i can deal with currently, i am stuck with 1.
As for hardware vlan issue, I see that now, but i cannot figure out how to do this without that.
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Management_access_configuration
and for all your other vlan’s:
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#VLAN_Example_.231_.28Trunk_and_Access_Ports.29
