I’m having a strange problem which is a bit frustrating. Once v7 was released I figured out that once upgraded the Hex S stopped showing any information about the SFP module which I’m using. I thought it was some kind of a bug in the new version, so I just downgraded and waited for few more bug fixes to come. Today I’ve decided to try it again and it’s still not available. Am I missing something or this is just a strange bug? I haven’t seen reports on this one. I’m using S-85DLC05D which had zero problems showing tons of information on v6.x.x.
I’d appreciate if there is someone with an advice or a similar problem.
I can not see any detail on 7.3.1 also on those models:
Working MikroTik S-85DLC05D
Working MikroTik S-31DLC20D
Working MikroTik S-35LC20D
Working MikroTik S-53LC20D
Working PLANET MGB-SX
Working AXCEN AXGD-1354-D533
But all working on 6.48.6.
I can confirm this also happens with mutliple deployed routers I manage after updating to v7.x, including HEX POE and HEX S models with different SFP modules installed.
On v6.x all these sfp modules had all the info details available there.
Is there maybe a solution available. If not, has a ticket already been open on this matter and MikroTik is working on a fix?
