Hi, I’m trying to do something probably trivial with a mikrotik hexs, basically I want do a port forwarding to redirect all traffic to the wan on a lan address where a simulator (ip 192.168.0.102) runs on port 105. Basically all the configurations I have implemented to redirect all traffic or just port 105 were unsuccessful. After the initially quickconf i have the wan address (static) on 192.168.51.150 and the lan address to 192.168.0.99. I used the following rules as per miktotic textbook
When i try with my laptop with 192.168.51.180 (connected with wan port) to connect to 192.168.51.150 the simulator that runs on 192168.0.102 does’t respond (ping always fails). When i connect the laptop to the lan ports with 192.168.0.x i can ping and query the app on 192.168.0.102 without problems.
The information missing from your post is: does router know it’s supposed to handle packets targeting 192.168.51.150? What is router’s own address in that particular subnet?
Generally adding DST-NAT rule doesn’t make router handle additional addresses.
To spare us from guessing, post full text configuration here. In terminal window execute /export hide-sensitive file=anynameyouwish, fetch resulting file, open it in text editor and copy-paste contents inside [__code] [/code] environment.
The explanation is still lacking.
Can you explain the use case or requirements without any mention of the config.
I need person X, or Device Y to be able to …
I am running a server and want devices or persons to … in relation to the server.
Mixing up the config with requirements leads to FOG.
Then I am doubly confused when you state you use laptop but from the WAN???
As for the config, it makes no sense to me!
You have one LAN subnet 192.168.88.1/24 which you have attached to the bridge.
Ether 2 is listed as a bridge port.
But then you give ether2 its own IP address.
If that is the case, take ether2 off the bridge.
PLUS
Where is the pool and the DHCP server etc. for the ether2 subnet???
Where is the dhcp server network for the bridge??
I am not conversant with how public IPs are distributed as often gateways are different from the actual public IP provided.
but yours appears to be a private IP, not sure why then the address and the network are so different .51 and .48 ???
Forward chain - last rule in the forward chain is a duplicate of a previous rule and can be removed.
_add action=accept chain=forward connection-state=established,relate_d
Since you have a static wanip the generic sourcenat rule can be modified to add action=masquerade chain=srcnat comment=“defconf: masquerade”
Other Sourcenat rule, no clue if its okay or should be stated prior to the default one above?
This dst nat rule is incomplete (you should be able to figure it out).
add action=dst-nat chain=dstnat dst-port=102 protocol=tcp to-addresses=
192.168.0.102 to-ports=102
OK I’ll try to be clearer, the router in question (perhaps used improperly) must be used to reach a particular machine in a private subnet with ip 192.168.0.102 on port 102, the wan is not connected to the internet but through a switch to a local network with subnet 192.168.51.x, all calls to the address 192.168.51.138 (which is now the static address on the wan - ether1) must be addressed to 192.168.0.102 (the application we are using use port 102), during quickconf I was asked for the LAN address and I entered 192.168.0.99. I am connected directly to the wan with a laptop to verify that the redirect in question works.
Also, if I am on a browser and am going out http or https ports 80 or 443 or for that matter
any browser entry in the form www.address.com:XXXX where port XXXX could be any port,
how is that going to come in on port 105 on the simulator???
/ip firewall nat add chain=srcnat action=src-nat in-interface=ether1 to-address=192.168.51.138
failure: incoming interface matching not possibile in output and postrouting chains
okay I see some are disabled and the last rule (sourcenat) is now in good shape (fixed).
this leaves one dst nat rule still in place. add action=dst-nat chain=dstnat dst-port=102 protocol=tcp src-address=
192.168.51.138 to-addresses=192.168.0.102 to-ports=102
Is the purpose of this rule to address people that are accessing the server from OUTSIDE the WAN, either on the external network the WAN resides or from the internet aka a public IP, on a router further up the food chain??
In any case the format for Dst-nat is as follows
add action=dst-nat chain=dstnat dst-port=102 protocol=tcp **dst-**address=
{note: to-ports not required if same as dst-ports)
That fixes all the config points now the challenge is to ensure all users on the LAN, when they use the application, get directed to the correct LANIP!
My question is what is the argument the application uses to communicate its outbound search?
How does the application on PC X, when you start it open, attempt to reach the server?
Does it have a domain name www.myserver.com for example?
If communication by the application is by domain name, then we can use DNS to force computers to that LANIP.
Assume application searches for domain name and its www.myserver.net
Pre STEP1 Work -Remove this current static rule or it will take precedence
/ip dns static
add address=192.168.0.99 comment=defconf name=router.lan
Ensure that this rule contains the dns-server entry!
add address=192.168.0.0/24 dns-server=192.168.0.99 gateway=192.168.0.99
Step 1. Put Script in STATIC DNS /ip dns static
add address=192.168.0.102 regexp=“(^|www\.)myserver\.net$” ttl=5m
This rule will capture any request for DNS when looking for that domain name and direct the query to the server IP.
However, some users on the same subnet may have DNS hard coded on their PCs… and thus you need to redirect all DNS queries to the router to handle.
add action=redirect chain=dstnat comment=“Force Users to Router for DNS - TCP”
dst-port=53 protocol=tcp src-address=192.168.0.0/24
add action=redirect chain=dstnat comment=“Force Users to Router for DNS - UDP”
dst-port=53 protocol=udp src-address=192.168.0.0/24
This should effectively ensure that regardless of PC DNS settings, all the queries from the subnet will go through the router and thus hit the static DNS rule created.
Two important points:
(i) You’d need to make sure “allow remote request” is turned on in /IP DNS, ( I see that is already in place!)
(ii) BE SURE that your input firewall filter blocks DNS requests from the Internet itself so that you don’t get this router taken over by a dns-amp ddos attack. This is not normally a concern if you are using the default firewall rules or any substitution thereof with a drop all else rule. (covered by your default rule, input chain does not allow any WAN incoming unsolicited traffic)
First of all thanks… the application that runs on ip 192.168.0.102 is a siemens cnc so there is no web application that could involve dns, i tried the last suggestion you made but when i try to connect on port 102 on 192.168.51.138 the connection is refused, i tried even telnet to 102 but with the same results… there are some detailed logs that i can check on the device ?
It is very likely that CNC gadget doesn’t have any routing enabled, so it can only talk to devices on same IP subnet. Which means you have to add src-nat which would make CNC gadget happy.
This rule should change header of every packet targeting 192.168.0.102 … it should change src-address to 192.168.0.99 (which is router’s address in this particular subnet).
You can make firewal rules log some headers of the packets they have processed, but in this type of investigation, it is usually either enough to look at the counters on firewall rules, or even their logs are insufficient and you need packet sniffing.
In the unlikely event that the suggestion of @mkx doesn’t resolve your issue, we may take that path (watching rule counters and sniffing).
Hi Mkx, thought you had given up on this thread or were using it as cheap entertainment watching me flounder around LOL.
Lets take the starting point discussion /ip firewall nat
add action=src-nat chain=srcnat out-interface=ether1 to-addresses=192.168.51.138
add action=dst-nat chain=dstnat dst-address=192.168.51.138 dst-port=102 protocol=tcp to-addresses=192.168.0.102
First rule, standard rule, tells the router for any outbound traffic from the LANSIDE please assign the IP so designated when leaving the router..
The second rule which says to me for any traffic heading towards the WANIP, on port 102, send this traffic to the LANIP.
The difference between this dst nat rule and the ones SIMPLE me is used to is that there is no reference to in-interface-list, meaning, the traffic we are directing can come from anywhere.
Thus not the Port forwarding I am not used to but okay DST nat is much more than that, and to keep Sindy happy/sane, I will allow it .
I am with you so far.
Then I get lost by this rule as I dont see how it applies???
add chain=srcnat dst-address=192.168.0.102 action=src-nat to-addresses=192.168.0.99 ???
That is GREAT news!!!, bu dont thank me, well okay maybe for confusing you, its all MKX… depressingly so LOL.
What is missing for me is the explanation of this statement which magically mks devined was the culprit.
What about the route already existing on the router??
add distance=1 gateway=192.168.48.1
What about if I had an FTP server for example.
Typically …oh…
I assign an IP address of 192.168.xx.yy and give it a gateway IP of the subnet
or it gets a DCHP assignment with gateway IP of the subnet
So in effect the FTP server knows where to send return traffic and that is to the gateway of the subnet and then routing takes over from there?
Is that the holy grail I am missing?
Well what kind of dipshit server does not have a gateway component of its address setup??
More to the point how the heck did MKX know this…
I am probably still wrong but getting nowhere fast is my motto. (Could be my reproductive motto as well, at my age).
If CNC gadget doesn’t use a router as gateway, then it can’t send replies back to outer network. Which means our beloved router has to fake return address so that CNC gadget thinks it’s talking to router when it’s not. Perhaps CNC gadget even does talk to gateway, but mikrotik doesn’t gave the right address? Who would have known …
Okay, can I ask you when the stock market will crash and also what date approximately I will expire so I can plan accordingly… fricken clairvoyant networker…
In terms of order, does the DST NAT rule have to be located before the new srcnat rule.
SO its like this.
dstnatrule
sourcnatrule
default normal sourcenat rule
In other words does the router have to state I have incoming from Joe blow and this traffic is going to 192.168.0.102
but wait, the next rule states
take that traffic and sourcenat it with IP 192.168.0.99 so it appears to hit 192.168.0.102 from 192.168.0.99 (vice joe blows public wanip).
When the return traffic leaves the server, the router unsource-nats the traffic so that it the destination gets corrected (it doesnt get sent to 192.168.0.99 but back to joe blows public wanip).
I am still fuzzy on NAT rules and if order applies in general.
