Good afternoon
I have configured a Hex-S router for one of our remote sites and sent it to site for one of our guys to install. They installed the router. It is currently connected to a BT router on eth1 with a switch connected on eth2. it is set to 10.124.1.1 and set to give IP’s in the range 10.124.1.2-10.124.1.254. This is working as it should.
BT have since been in and fitted a new fibre route, Cisco 4321. Site have disconnected the Hex-S from the BT router and plugged it into the GE 0/0/1 port on the Cisco router via Cat5 but the Hex-S is failing to pick up an IP address.
I have had one of our guys on site connect his laptop to the Cisco router via the GE 0/0/1 port and he gets an IP address. This is a 169 address but he gets internet access. The gateway address is an IPv6 address, FE80…
If I connect the Hex-S back up to the Cisco router, it still refuses to get an IP address. I’ve tried setting a static IP for the eth1 but I can’t add the IPv6 address in the gateway.
Would anyone have any ideas how I can get this connected and working?
We had fibre installed in another depot and used a Ubiquiti EdgeRouter x4 and had no issues, it just worked straight away.
Alex
