Hex-S trunk port works, access ports do not.
Hi folks, im somewhat at a loss here, I am intending to use a HEX-S as a media converter for Fiber services. A management interface is configured on Vlan 3049, which works. It seems am unable to get vlan 3050 (internet to client) passed thru to ether port 1 or 2. DHCP doesn’t pass, nor do I get internet when I hardcode the laptop with an IP on a subnet on that vlan. The trunk port works, because if I change the vlan on the management interface to 3050, the dhcp client grabs an ip from that subnet. My access ports (vlan3050) on ether 1 and 2 do not.
I was using the guideline here; Basic VLAN switching - RouterOS - MikroTik Documentation
[admin@MikroTik] > export
2025-05-30 15:44:49 by RouterOS 7.19.1
software id = GDG8-02B8
model = RB760iGS
add name=bridge1
/interface vlan
add interface=bridge1 name=MGMT vlan-id=3049
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp1
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=3050
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=3050
/interface bridge vlan
add bridge=bridge1 tagged=sfp1 vlan-ids=3050
add bridge=bridge1 tagged=sfp1,bridge1 vlan-ids=3049
/ip dhcp-client
add default-route-tables=main interface=MGMT
/system clock
set time-zone-name=America/Edmonton
Appreciate any help!
Well since you seem you want to use bridge vlan filtering you must enable it on the bridge itself:
/interface/bridge/set vlan-filtering=yes bridge1
Adding to post by @itimo01 above: the other thing is the bug about handling VLANs between switch chip and CPU, addressed by 7.20beta:
*) bridge - added dynamic tagged entry named “switch-cpu” in scenarios where the same VLAN spans multiple switch chips or is used on both HW and SW ports;
Doesn’t mention this exact scenario but I’m pretty sure it does apply: SFP port is not on same switch chip as RJ45 ports.
You can try with a manual work-around: set bridge interface as tagged member of VLAN 3050 … without creating corresponding VLAN interface.
Be warned that this is not a recommended configuration, as all bridge traffic will be passed on to cpu. Depending on the volume of the traffic that might become a bottleneck.
Yeah the block diagrams are not helpful.......
If this doesnt work then perhaps the other suggestion by mkx may bare fruit.
model = RB760iGS
add name=bridge1
/interface vlan
add interface=bridge1 name=MGMT vlan-id=3049 vlan-filtering=yes
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp1 comment="trunk port to upstream router"
add bridge=bridge1 tagged=sfp1 untagged=ether1,ether2 vlan-ids=3050 { not mandatory in this case but clarifying }
add address=192.168.99.2 (fixed address on vlan management) interface=MGMT network=192.168.99.0
/system clock
MISSING:::::::
add name=TRUSTED
add interface=MGMT list=TRUSTED
set discover-interface-list=TRUSTED
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
I turned off bridge filtering at one point because it locked me out of winbox on the lan side. When enabled, behavior was the same.
I ended up just creating vlan interfaces and adding them to the bridge (with hardware offload). It seems to work good enough even tho cpu hits about 20-30% when doing 1 gbps.
That seems to work ok. We have just enough grunt to rate limit at 500mbps when everything goes over the CPU on these little units.
Thanks!
Yes, my typical advice to combat frustrating bridge vlan setups is…
Also to work on vlans as it can get sticky when applying vlans or trying to change from default to your stetup, its best to do so from a safe spot. Saves much grief!
So use an off bridge port for the configuration and also as an emerg access port on the switch at any time…
Associated config entries ( remove ETHER5 from the bridge in /interface bridge port settings) :
set [ find default-name=ether5] name=OffBridge5
add address=192.168.77.1/30 interface=OffBridge5 network=192.168.77.0 comment=“Offbridge and Emerg access”
add interface=VLAN10-Home list=TRUSTED
add interface=OffBridge5 list=TRUSTED
Note: to access the router simply configure your PC/laptop with IPV4 settings of 192.168.77.2 and via username and password you should have access.
Assumes
add name=WAN
add name=LAN
add name=TRUSTED
Additionally
/ip neighbour discovery-setting
set discovery-interface-list=TRUSTED
/tool mac-server
In this case, 1gbps is all we need.
In our other use cases, we need all the traffic hitting the CPU to do simple queue rate limiting per port.
Ive gone down a bit of a rabbit hole in regards to vlan filtering today. Ill probably review my concept once i’m local to the production environment Tho in our use cases, im not sure if its required as they are basically being used as smart media converters.
Interesting this setup didn't work at passing 3050 to ether5 (access port) until I enabled vlan filtering and associated bridge port rules.
add name=BR1 protocol-mode=none
/interface vlan
add interface=BR1 name=vlan1 vlan-id=3049
add bridge=BR1 frame-types=admit-all interface=ether1
add bridge=BR1 frame-types=admit-all interface=ether5 pvid=3050 trusted=yes
add bridge=BR1 tagged=ether1 vlan-ids=3049-3050
/interface vlan
/ip dhcp-client
add default-route-tables=main interface=vlan1
This one works tho;
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface vlan
add bridge=BR1 frame-types=admit-only-vlan-tagged interface=ether1
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=
/interface bridge settings
set use-ip-firewall=yes
/ip dhcp-client
Ill see if I can lab this with the SFP in the mix, current config is full hardware offload 0% cpu usage (according to the telnet session from the tik upstream of this cpe)
