Does HEX S will be enough to run User Manager for maximum of 300 clients? Should I buy SD Card for storage ? Or should I forgot it and install RouterOS on x86 architecture, because HEX S won’t have enough processing power?
I don’t have any experience with RADIUS running on Mikrotik device so I hope you guys will give me some advice and maybe few tips and tricks. THANK YOU!
Although your sarcastic comment is appreciated it’s not what I needed. At least you could tell me what CRR should I use…
Anyway I suspected that it won’t be enough (reason I’ve asked you guys here) but i’m working with what I got. Client is public school which as you can imagine trying to safe every penny they can hence they thought that it would be a brilliant idea to join this BS Eduroam project but don’t want to spend money for a Linux server or powerful router.
Thank you for the analogy though, i’ll make sure to use that one to explain it to their “IT” departement.
hey , first of all , i think you should check if the HEX lisence level will make you able to run 300 clients , in my openion , HEX with an SD card with HOTSPOT will run just fine , but i have to ask about the speed you are willing to get of course . i am running hex for about 50 clients with 2-4mbps and it is working just fine
I have recently bought a RB750GR3 for my internet cafe. I setup hotspot using radius aunthentication but I am failing to access my user manager page. Please assist
