Hello:
I have a HEX-S (RB760iGS) as a home router and I’m having a bit of an issue getting it to play nice with VLANs. Per my understanding, this chipset (MediaTek) only supports VLANs at the Bridge level. I have followed the wiki guides but failed to get it working. Here is what I am trying to do:
ETH1 => WAN (public IP)
ETH2 => VLAN tagged trunk supporting three VLAN 10/20/30 (this port goes to a CRS…)
VLAN10: 192.168.10.0/24
VLAN20: 192.168.20.0/24
VLAN30: 192.168.30.0/24
ETH3 => untagged VLAN10
ETH4 => untagged VLAN20
ETH5 => untagged VLAN30
The HEX will handle NAT and inter VLAN routing.
Is this configuration possible?
Thanks forward.
This was my solution
http://forum.mikrotik.com/t/vlan-bridge-with-filter-problem-hex/137623/3
Unfortunately, that didn’t work for me.
Then you should probably post you configuration here
add name=bridge_trunk
add name=bridge_vlan10
add name=bridge_vlan20
add name=bridge_vlan30
set [ find default-name=ether1 ] comment="-- WAN --"
/interface vlan
add interface=bridge_trunk name=vlan10 vlan-id=10
add interface=bridge_trunk name=vlan20 vlan-id=20
add interface=bridge_trunk name=vlan30 vlan-id=30
add bridge=bridge_trunk interface=ether2
add bridge=bridge_vlan10 interface=vlan10
add bridge=bridge_vlan20 interface=vlan20
add bridge=bridge_vlan30 interface=vlan30
add bridge=bridge_vlan10 interface=ether3
add bridge=bridge_vlan20 interface=ether4
add bridge=bridge_vlan30 interface=ether5
Put ip addresses on the bridges for each vlans !
Here is my non working configuration:
set [ find default-name=ether1 ] comment="WAN Port"
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan30 vlan-id=30
set 1 vlan-mode=disabled
set 2 vlan-mode=disabled
set 3 vlan-mode=disabled
set 5 vlan-mode=disabled
add bridge=bridge1 comment=defconf interface=ether2
add bridge=bridge1 comment=defconf interface=ether3 pvid=10
add bridge=bridge1 comment=defconf interface=ether4 pvid=20
add bridge=bridge1 comment=defconf interface=ether5 pvid=30
add bridge=bridge1 comment=defconf interface=sfp1
/interface bridge vlan
add bridge=bridge1 tagged=ether2,bridge1 untagged=ether3 vlan-ids=10
add bridge=bridge1 tagged=ether2,bridge1 untagged=ether4 vlan-ids=20
add bridge=bridge1 tagged=ether2,bridge1 untagged=ether5 vlan-ids=30
add disabled=yes ports=ether4,switch1-cpu switch=switch1 vlan-id=10
add disabled=yes ports=ether4,switch1-cpu switch=switch1 vlan-id=20
add disabled=yes ports=ether4,switch1-cpu switch=switch1 vlan-id=30
add address=192.168.10.1/24 interface=vlan10 network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
Not surprising seeing as you didn’t enable bridge vlan-filtering.
Sorry, I should have pointed out that after setting the above config, I enable vlan filtering on the bridge and then the unit becomes unreachable…
Hi All:
Just wanted to share the configuration that worked for me on the Hex. In this configuration, which is a starting point, I ended up implementing the following:
ETH1 => WAN
ETH2 => VLAN trunk for VLAN 10,20,30
ETH4 => VLAN 30 untagged.
Thanks for the suggestions, hope this helps others.
# model = RB760iGS
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge1 \
vlan-filtering=yes
/interface vlan
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=All-LAN
add name=pool-vlan20 ranges=192.168.20.100-192.168.20.199
add name=pool-vlan10 ranges=192.168.10.100-192.168.10.199
add name=pool-vlan30 ranges=192.168.30.100-192.168.30.199
add address-pool=default-dhcp interface=bridge1 name=defconf
add address-pool=pool-vlan20 disabled=no interface=vlan20 lease-time=30m \
name=dhcp-vlan20
add address-pool=pool-vlan10 disabled=no interface=vlan10 lease-time=30m \
name=dhcp-vlan10
add address-pool=pool-vlan30 disabled=no interface=vlan30 lease-time=30m \
name=dhcp-vlan30
add bridge=bridge1 comment=defconf hw=no interface=ether2
add bridge=bridge1 comment=defconf hw=no interface=ether3
add bridge=bridge1 comment=defconf hw=no interface=ether4 pvid=30
add bridge=bridge1 comment=defconf hw=no interface=ether5
add bridge=bridge1 comment=defconf hw=no interface=sfp1
set discover-interface-list=All-LAN
add bridge=bridge1 tagged=ether2,bridge1 vlan-ids=10
add bridge=bridge1 tagged=ether2,bridge1 vlan-ids=20
add bridge=bridge1 tagged=ether2,bridge1 untagged=ether4 vlan-ids=30
add comment=defconf interface=bridge1 list=LAN
add interface=bridge1 list=All-LAN
add interface=vlan10 list=All-LAN
add interface=vlan20 list=All-LAN
add interface=vlan30 list=All-LAN
add address=192.168.30.1/24 comment=defconf interface=vlan30 network=\
192.168.30.0
/ip dhcp-server config
set store-leases-disk=15m
add address=192.168.10.0/24 gateway=192.168.10.1 netmask=24
add address=192.168.20.0/24 gateway=192.168.20.1 netmask=24
add address=192.168.30.0/24 gateway=192.168.30.1 netmask=24
add disabled=yes distance=1 gateway=192.168.30.1
/tool mac-server
set allowed-interface-list=All-LAN
/tool mac-server mac-winbox
