HexS - does thiis configuration looks ok
My only goal is to have a LAN and and IoT Vlan, it just seems so difficult.
Here’s my config, I just need to see if the firewall is still somewhat in default state to give me out of the box protection. Secondly, the Vlan20 does not have access to Lan devices.
# jun/12/2021 15:15:29 by RouterOS 6.48.3
# software id = 5MZ7-RL5B
# model = RB760iGS
# serial number = E1F30D1CB7FB
add admin-mac=08:55:31:CD:0D:6A auto-mac=no comment=defconf name=bridge
/interface vlan
add comment=Iot-vlan interface=ether5 name=VLAN20 vlan-id=20
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.4.20-192.168.88.200
add comment="DHCP pool for iot-vlan" name=dhcp_pool2 ranges=\
    10.0.20.2-10.0.20.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool2 disabled=no interface=VLAN20 name=dhcp1
add bridge=bridge comment=defconf ingress-filtering=yes interface=ether5 \
    pvid=20
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=none
add address=192.168.4.1/24 comment=defconf interface=bridge network=\
    192.168.4.0
add address=10.0.20.1/24 interface=VLAN20 network=10.0.20.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.0.20.0/24 comment=VLAN20-untrusted dns-server=8.8.8.8,1.1.1.1 \
    gateway=10.0.20.1
add address=192.168.4.0/24 comment=defconf dns-server=\
    192.168.4.209,192.168.4.208 domain=clubamgg.com gateway=192.168.4.1 \
    netmask=24
/ip dns static
add address=192.168.4.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.4.0/24 list=trusted
add address=10.0.20.0/24 list=untrusted
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=forward dst-address-list=untrusted src-address-list=\
    trusted
add action=drop chain=forward dst-address-list=trusted src-address-list=\
    untrusted
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2200
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=America/New_York
/system identity
set name=router
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
(1) ERROR
add name=dhcp ranges=192.168.4.20-192.168.**88.**200
(2) to access winbox set this to safe subnet…
set allowed-interface-list=MNGMT
Where
add name=MNGMT
add interface=vlan20 list=LAN
add interface=bridge list=MNGMT
(3) This can be set to MNGMT
set discover-interface-list=MNGMT
(4) Dont forget you need to enable the checkbox for vlan filtering on the bridge.
@anav
Thank you.
I took care of the first 3 as you suggested.
For #4, I checked the VLAN Filtering, for the Frame Types “admit all”? Which one from the drop down to pick?
The port#5 in the router is carrying both Vlan20 and lan traffic to Unifi switch, which seems to be working already.
the one I am talking about is located when you double click (left) on the bridge itself.
Brings up a popup menu look under VLAN, and the box next to VLAN filtering.
Is this what you mean?
Yup… lucky find LOL
Although you dont really need a vlan for bridge vlan filtering if you ONLY HAVE ONE VLAN on one port.
Vlans come into play when you have more than one subnet required on a single port.
