HexS / RB760iGS inconsistent PoE output after reboot
Hopefully someone else has also experienced this or can shed some light on the behavior I’m seeing. I currently have RB760iGS (Hex S) running in a controlled test environment. Port 5 PoE output is enabled and is powering a WiFi AP.
When I do a quick reboot or power-off/power-on, the Hex S reboots, but the PoE output does not come back on. If I unplug the Hex S and let it sit for approx. 3 minutes, then plug it back in, it boots up and PoE output works just fine again.
Is this a known issue? It seems to me that a capacitor needs to fully drain (or something similar) before the router is able to bring the PoE output back online. This is a complete wild guess, however :slight_smile:
Thanks for any feedback.
RMA?
Regards.
After contacting support@mikrotik.com or contacting support of your seller.
Here’s my update for this issue. Have been advised by support to RMA my original Hex S. It turns out that the initial production of RB760iGS/Hex S has this problem, and also specifically will tell you that PoE “auto-on” setting is not supported should you try to enable it on the interface.
I’ve purchased a new Hex S which now does support the PoE auto-on setting and also definitely does NOT exhibit my original problem. The PoE output now works consistently when set to “forced on” every time this new Hex S boots, regardless of power loss or what have you.
If you have recently purchased a Hex S that has these PoE problems, and you want the PoE output to work consistently and/or need the PoE auto-on feature, RMA your device. Assuming it’s still under warranty, that is - my RMA was denied since I bought it well over a year ago. Now I’m stuck with the bad router, but will simply use it for experiments or testing as it works OK besides the PoE problems.
Note that I did disassemble both of these routers for inspection and there are obvious changes to the hardware to correct the PoE problems - most notably a completely different relay, capacitor and some minor circuit design changes.
Happy routing everyone :slight_smile:
Can you put some pictures here?
